Why you run 91? Super high compression.
Only 9.76Why you run 91? Super high compression.
You suckWe don't do E85 here. E10 is max. 87 is 10%, 89 is 5% and most places the 91 is real gasoline with no ethanol.
You suck
OK...good. Going to follow how you replaced your fuel lines. I want to get rid of all the hard lines including the 4L80E. I'm new to the AN fitting regime so there is going to be a learning curve.
Thank you
Only 9.76
Every time I have done a mileage test on one of my vehicles, I have put it on a spreadsheet and figured cost per mile for each fuel used, and carefully notated driving conditions
Each time I have found the increase in mileage offset the increase in cost or more
Haven’t tried lower octane on this engine. On the old engine it would diesel so bad at 14* lead you had to drop it back to 8. Nothing here likes 8 degrees. Altitude sucksI thought I was the only one who would do that.
Added value pays off more often than it doesn’t.
On another not my dad bought an engine from Ray Barton one time and we went up there and watched them dyno it. It made more power on lower octane at a given timing setting. Logic being that the lower octane burns slower and hotter. The only reason the higher octane makes more power is that it burns faster and subsequently allows higher timing.
Actually lower octane has more energy that is why it gets more mileage.I thought I was the only one who would do that.
On another note my dad bought an engine from Ray Barton one time and we went up there and watched them dyno it. It made more power on lower octane at a given timing setting. Logic being that the lower octane burns slower and hotter. The only reason the higher octane makes more power is that it burns faster and subsequently allows higher timing.
Noticed E15 around here recently. I think that's all you can get in Iowa.We get 85,87,91 all 10% ethanol
We had E85, still see it in some stations
The 87 no ethanol is fairly recent change here. Discussion of others non-ethanol, but not yet
I’d really like to get back 91 no ethanol
You should use the lowest octane that will work on your engine without detonating.
The lower the octane the closer to diesel which is the higher in energy.
The high octane is refined more and has less oil in it basically which can detonate under high pressure.
Now octane aside, any fuel with ethanol will have a lower mileage than the worst straight gasoline.
Unfortunately in California there are only a handful of stations that still carry the no ethanol fuel and the closest place is 3 hours from me.
And when I tried using 85 octane on the old engine, I had to back the lead down about 10 degrees. The mileage certainly was not betterYou’re right so it’s actually compression (not necessarily timing) that causes the higher octane requirement.
That's why I said you use the octane rating that works without detonation.And when I tried using 85 octane on the old engine, I had to back the lead down about 10 degrees. The mileage certainly was not better
There’s no 89 here. The 4 octane I’d be giving up to 87 is a lot, and I’m not sure that benefits would ever be seen based on all the times I’ve already ran fuel mileage testsThat's why I said you use the octane rating that works without detonation.
If at the timing you need it doesn't work it means you raise the octane instead of compensating with the timing.
But if 89 octane works for you and you use the 91 you are leaving something on the table is all I am saying
