I might have pics this weekend. @skunked might have some good pics without a bed in the way.
Here's the carb tank I ran before
The 40 gallon is longer, would have interfered with my axle.
Only difference between the 25 and 31 is height.
I guess I've never looked at a factory 40-gallon application. How do they come forward without hitting the axle? My Suburban doesn't have a huge amount of clearance between the axle and the 31-gallon tank (actually, I think it was 33 gallons when I pumped it out and filled it up). Is the small Suburban tank different from the large K5 tank?
A Suburban tank and or a Blazer tank should fit fine in a pickup. They have more space behind the rear wheels to the bumper then both of them do. Or at least the same as a Burb. The only thing you are going to lose is departure angle
I thought the rear axle in a Sub. was pushed forward 3" compared to a LWB pickup. I know the sheet metal is the same length front to rear.
So height between 31 and 40 gallon is the same?
Not sure
How much height?
Couple inches
I don't think a burb tank will fit in a short bed, it was difficult enough fitting a k5 tank and my rear axle is not pushed back.
K5 and short bed same size in the back ?
Burb is shorter then a long bed for sure.
I haven't measured from bumper to axle, but a K5 bed is shorter overall than a shortbed (5.5' vs 6' 3" inside dimension), and a suburban "bed" is the same length as an 8' 3" longbed on a pickup.
Again, these are sheet metal measurements, I haven't measured frames.
At least, not yet. :thinking:
With the blazer and or burb tank what are you going to do with the filler neck? This is on my list of to do's
