the chambered side exhaust are still available...bout 500 frogskins for a pair...
I just built full 3" duals behind my stock high mile TBI 350. I used the Super 44's.
Yes single 3" might be better, but this truck will be getting a big block in the future...
maybe a bit rich?With 3in true duels back pressure can be a problem. I have 2 1/2 true duels and you can here them pop when the idle comes down after I rev it. You may be ok if you can fit an H pipe but its real tight underneath
like it Rene', thats with the H pipe too right?
So a balance tube will stop that. Where did you put the tube at?
I put it right below the output on the T-case. It's about even with the bottom of the frame.
