. And it's light...only 1600 lbs dry...so that is really nice.Motorcycle racers use those.
How does an ice box not work? You put ice in it , it gets cold.
It leaks
Minus the obvious outside difference, the brackets are identical on the inside. I loved them. Super easy to adjust and held it down nicely.@GWeakland620, for your tie down situation like in the picture below...are those the style that just bolt to the inside of the truck bed? If so, where did you get them? Are they similar to these: https://www.etrailer.com/tv-review-brophy-angled-hold-downs-for-truck-bed-campers-hsab.aspx
Not that I switched trucks a lot, but the no drilling aspect appealed to me for removal when I was using the truck to do other truck things. Didn't always want those brackets hanging out on it. Only had 1 head injury, but didn't like them sticking out.Cool, thanks! I've found a few places that seem to carry pretty much the same thing, so I'll pick up a set for mine. The fact they just bolt up to the bed without drilling is very beneficial for me...since I have a few trucks that my camper will potentially go into, it will be nice to have a set of those brackets just stay with the camper, and whichever truck it'll go into I just hook the brackets up real quick (instead of having to install fixed mounts onto each truck). Thanks for the info!
It's easier if the wife don't work.I need to take my camper out. Last and only time we used it was koh. Work is killing my not having the same days off as the wife
