Yes, Do not crank it in with the bell housing bolts! Literally just try to wiggle the crap out of it while pushing it in. Up down left right. Also helps if you put it in gear and try to turn the output shaft back and forth while pushing and wiggling.
That's the plan. But I want to have the ability to stop the bell housing from rotating so I can focus on just the shaft. The tranny has fallen out of place a number of times, and then I hafta realign the shaft to get it to slide forward again.
It's close to going in, and I know the splines have engaged (can't turn the output shaft anymore). So I'm nearly there. Just need some more fiddle time with it.
