Alright. The K5 is running. Almost everything has been fixed. Exceptions are the speedometer (shredded both gears in the T-case). It's the 41/15 Yellow/Grey gear combination, and the speedo was dead on with this ratio. Still not sure how that's possible, given the regearing.
But I don't feel like pulling the T-case apart. And if I've run out of desire to fix it, now is a great time to sell it (no, I'm still not looking forward to it).
Also haven't fixed the E-brake (which I never intended to fix), backup lights, or the cracked mirror. Other stuff all works.
Next step is writing up an advert. So far I have not been any good at selling vehicles, so I'll take whatever input you guys have. I think I'll throw it on Ebay first for crazy money to see if it gets any bites. And then post a real ad up after that goes nowhere. I like the Detroit, and I don't think it adds much to the resale value, so I've been planning on pulling that out for the next project. Same for the $100 Tinytach (I'd just put the old voltmeter back in that hole).
Here are my rough thoughts on what an ad should look like. Too wordy?
1986 Chevrolet M1009 (D10 Military Blazer)
Odometer reads 47,000 miles
6.2L diesel engine
NV4500 manual transmission
NP208 transfer case
3.73 axle gears
GM 3/4-ton 10-bolt front axle with Eaton Posi.
GM 1-ton 14-bolt full floating rear axle with Detroit Locker.
Previous owners claimed to have completely rebuilt both axles. I changed fluid in both axles and added the Detroit to the back. E-brake cable is missing.
5-speed NV4500 manual transmission swap completed in late 2016. At that time I also installed:
* All new clutch hydraulics.
* All new shocks.
* Rear main seal.
* New glow plugs, rewired to run off of 12V instead of 24V (24V system is otherwise stock).
I have been daily driving it since then.
Other mods include:
* Manual glow plug switch (previous owner).
* Electric fuel lift pump.
* Dual voltmeter (independently measures 12V and 24V systems).
* TinyTach diesel tachometer. I was going to keep this for my next project, but the speedometer gear shredded recently and I have run out of time to fix it.
* Tires are 245/75R16 on newer 8-lug rims. 75% tread.
* Driver seat & front seat belts taken from a newer truck. I'll include the matching passenger seat (split bench) if desired.
* Rear window has been converted to a liftgate from a pickup topper.
* Bluetooth/USB/AUX/FM stereo.
* Adjustable proportioning valve to set the ratio between front and rear brakes.
The truck is eligible for Military Vehicle plates, but has a clear (civilian) title in my name.
