You were jammin too hard
I was in a good mood, just got off work, nice day, good tunes, then this. But I'll keep jammin hard foreverYou were jammin too hard
I hope so, the new gear had almost no play in it so I think I'm ok.Ouch, how'd you manage that? Is the gear on the cam ok?
Or did it not shear, it just wore out the gear?
Why would it shear ? Would be the guestion I would be trying to answer.
Oil pump going out?
Distributor shaft bent ?
Only two things that it does
I put a new filter on and have a magnetic drain plug, so if it has filings I'll be worried then, but otherwise I think I'll be ok.Doesn't sound like it would be a bad idea to pull the pan and clean it out and eyeball everything.
