Perfect for when you want to grow!Yeah, anything that bolts up to the hemi heads on a hellcat/trackhawk.
You mentioned good deal on the blower - whats considered a good deal on these? Ive seen a couple on FBMP near me, but not new factory take offs
I mean, equivalent superchargers good for 1000hp w/intercooler run ~7-9k ballpark new, you can find em for 4-7 used depending on how rough they are. I ended up getting this low-mileage dealership take-off blower, complete with all sensors, fuel rails, throttle body, snout, Hellcat injectors, and an extra bypass valve for $1500. Most of them out there don't have fuel rails, bypass valves, or throttle body because people keep those. I was interested in anything $2500 or less as long as it looked decent, I feel like that's a good enough deal to justify the work needed to fit it. BUT, fuel rails for the hellcat blowers are FOUR HUNDRED TO FIVE HUNDRED DOLLARS just for the rails! Even stock takeoffs on Ebay are $350+ when I was looking. Keep that in mind when you're lookingPerfect for when you want to grow!
I'm happy to be the guinea pig, my man! I'm a textbook overthinker and planner, and I'm confident I've figured out the best and most cost effective way to get this thing running and reliable. Time will tell! I keep track of every single thing I buy and every penny I've spent, so I'll post the full detailed budget at the endDefinitely watching how this turns out. I was planning to run a blower on a LS/LT, so this may be a more affordable option. I quite a ways away from that at this point though.
Sorry, sounds like I misspoke. The 383 was in the stock location, but the 4L80 pushed the transfer case back, requiring driveshaft work, a custom trans mount, a trans crossmember-front shaft clearance issue, longer shift linkage, and the 4wd linkage/wiring didn't reach. The engine will now be ~1.5" forward from stock, but everything else mentioned above will return to about stock location/setup. I just hope it doesn't make my crossmember-pan clearance too much worse.So you were currently 1.5” back from stock when you did 383, so now you are essentially bringing back to stock location and that should clear?
Very cool to see it in the engine bay!
I have! DJ is where I got my adapters, pulley hub, and bypass valve controller. Super cool guy, very helpful, and the best prices by a MILE. That page only provides the scales for the MAP portion though, and not the fuel pressure sensor or the temperature portion of the TMAP. He said he would update his site when he gets ahold of the actual tablesNot sure if you have seen this page but it shows what connectors to use and the sensor scales.
https://djtuning.com/products/gen-iii-iv-ls-cathedral-hellcat-supercharger-adapter-pre-order#:~:text=This is a set of,Gen V LT Based engine.
Keep up the work, been watching this.
