Are you going to play jimi hendrix in that bad boy?
just sayinI'll admit even my short throw had problems shifting in the sand and its a hell of a lot faster than a 465. But if you have enough rpms you can pick a gear and burry it till the top. That's what I did and it would have worked better if my suspension could keep up with the rpms. I suspect Nate's crazy lift won't take much speed to start bouncing hard on the bumps and whoops.
Although in the dunes the SM465 would be pretty worthless, unless he just wanted to tool around on the bottom flats all day, boring! I would of swapped it out faster than you could of shifted it out of granny gear!![]()
I'll admit even my short throw had problems shifting in the sand and its a hell of a lot faster than a 465. But if you have enough rpms you can pick a gear and burry it till the top. That's what I did and it would have worked better if my suspension could keep up with the rpms. I suspect Nate's crazy lift won't take much speed to start bouncing hard on the bumps and whoops.![]()
As far as harness tips, read through this on lt1swap.com and just follow his instructions. Its easy if you just do it step by step. He also has more pics on FB.
http://lt1swap.com/2000harness.htm
Thanks. This is exactly the link i was looking for. Came across it a while back bit didnt save it and couldnt remember it for the life of me.
As far as a cross member getting a tna crossmember from ben he had. So once he stops complaining how hot it is and gets it to the shipping center ill have that.![]()
Evil.
