I’ve spent a lot of time thinking about how I’m going to hook the winch cable to the tire rack, and I’ve found a solution:
I’ll use one of these trailer D Ring shackles and weld it to the rack, next to the hitch pin tabs just to the left, slightly forward so as not to interfere with the hitch pin.
I’ll also use this heavy duty carabiner in lieu of the provided winch hook, as the hook doesn’t give me much confidence on its strength and the carabiner is a sleeker more tire friendly design. If it doesn’t work out, I’ll revert back to the hook.
This all should give pretty decent rotational flexibility as the rack moves up and down (that’s me trying to sound like I know what I’m talking about).
And here is my draw-up of my final plans for the roof rack via the poor-man’s BendTech: Paint.
This build is an experimental gamble in attempting weight reduction via thinner tube. The structure I have built so far is built from .095, but I have additional tube coming today in .120 that I’ll use for 3 additional lateral supports (red), as well as, the framing for the winch mount (green). The actual roof mounts (dark blue) are 1/8” thick flat stock and will bolt to the roof via rivenuts. The base of the winch mount will be cut from scrap 1/4” plate (light blue) I have on hand and have 2 - 3 different mounting locations drilled so I can get the offset just right to be able to open the passenger door without disconnecting the winch cable. And finally, I am adding side “risers” (purple) for the simple purpose of keeping me from rolling off the rack when sleeping up top. Since these won’t have any purpose other than general fencing duty, I opted for .065 wall tubing, and that’s arriving today.
Also, I have several of these tiny 1.75” gussets from Summit that I’m sure will add some level of strength in the legs and maybe risers, but really are more for giving tie down points. So between those, the expanded metal that will cover the entire rack, and the extra weld-on D rings that come in the pack that I’ll put to use, I’ll have INFINITE tie down possibilities.
It’s my goal to get all this finished by the end of this weekend for 2 reasons: we are going on a nearby camping trip next weekend and I’d like to sleep up top, but also, Ive committed to 3 other projects for others that are due by thanksgiving, so I need to get to those asap. There’s a good chance though that I won’t get it all done and may need to put this on the back burner until December or maybe even after the new year. But I’m going to be hammering down big time on this for the balance of the week, so maybe I’ll get lucky.
Another step is dealing with the sharp edges of the expanded metal. I could just leave it, but I’d prefer to not do so due to risk of people cutting their fingers. Only sure fire way I can think of is to get the dremel and the grinding wheels and get to work. Talk about time consuming.
Time to get to work.
Andy
