Derek Weeder
Registered Member
shop vac in the radiator will keep the coolant loss to a minimum.
I've always done mine parallel to the axle tube. I see the idea there to match the factory angle. I suppose that should work just fine. I still wouldn't recommend the single tab setup.
Yes it would be like that. I have had mine mounted on top of the axle tube like your single tab is, but rotated 90 degrees. I like the set DIY4x sells that overlaps between the axle tube and the inner c. I'm talking for a Dana 60.I am fine with whatever more experienced persons than myself recommend. Parallel makes sense. Looks like those single tabs would result in the shock stud being parallel to the axle tube.
Or, when you say the tabs should be parallel, are you referring to something more like this?
You might have to move the top mount higher with the knuckle tabs. Its how i have mine mounted as well.
For time sake I’ll probably go with the fords.
These next 12 months are going to be a big year. Planning a big road trip for next July and a lot will be getting done in these 12 months.
Will using these require me to get longer shocks or will I still be able to use the Bilsteins I have?
I know you already ordered the tabs. But if I were in your situation I would buy/build tabs that matched my current shock placement. Unless you need to replace them, or there's some issue with how they're mounted, I'd stick with what you have (because you know it works).
Raised shock towers work, but they aren't easier to service. You may want the extra height for long-travel monotube shocks, but it does increase the congestion. You will probably wind up hacking the inner fender to let them fit, and the A/C box limits how high the passenger-side bracket can be mounted. Rotating the axis of the lower bolt means that any rotational movement at the bottom of the shock is twisting the bushing itself rather than rotating around the bolt. Not great for a suspension that needs to actually move.
Think through the potential problems before picking a particular geometry. It's a lot easier to change things now, before you start burning metal.![]()
