To check the frame measure diagonally on the side not damaged and compare to the other side.Now that the adjuster has seen the truck, I can get to work. With this hurricane coming, I didn’t exactly want the truck sitting under a bunch of trees. First step was to remove the fender, which I pretty much had to cut off.
Then I had to loose the axle and straighten it out. I do not think the axle has suffered any damage. You can see here how far it slid back though.
The center pin on the leaf sheered off and back she went. This caused one of the u-bolt studs to snap off, so I’ll have to figure out how to get that out. The u-bolts on both sides are twisted so they will have to be replaced.
I then pulled the spare out and threw it on. Once the axle was straight and back on two tires, the waves in the driver side spring pack settled out, which I am thankful for. Neither spring pack appeared to have suffered damage. The pass shock is bent though.
I then grabbed hold of the grill and yanked back on it as much as I could to get it off the fan.
I am happy to report that she still moves under her own power, and all of her major systems appear to still work, except for the radiator, which suffered a puncture somewhere. The engine cranked just like normal, oil pressure was perfect, brake pressure was perfect, steering operated perfectly, even the A/C still worked!
I know the frame is tweaked some, but I can’t tell how much. Any ideas on how to test?
As far as next steps, I am torn on which direction to go. We have a number of options we are thinking through, and ultimately what State Farm does will be the deciding factor.
For now, the rest of the weekend likely involves hurricane prep. Unfortunately, she will have to sit this one out, but hopefully no rescue operations will even be needed.
Andy
I usually use a specific hole or bracket and measure to something in the back of the truck.
All measurements should be equal.
And keep documenting here this is the best way to keep track of the damage and cost for the claim
Nice
