Time for an update I suppose. As
@KirsL says, we’re in the last 10% that takes 90% of the time. Full transparency here: I’d be lying if I said I wasn’t completely burned out of steam. Trying to find the right balance between producing the best product I can and just getting it done. Perhaps this is a good time to take a break and get some work done on my wife’s truck.
Wait, how is that a break?
I digress...
To recap where I’m at, I decided to replace the headlight buckets. New side marker lenses also. And one 1/4 NPT zinc anode plug for the radiator. Yes, that’s double stacked rubber underneath the radiator. Turns out the height of the lip where the tanks and the core join is about a quarter inch short.
Then it was time to sort out the wiring. It was obvious that the wiring had turned into a rats nest with all of the gadgets and gizmos that I had added over the last few years, so I wanted to take this opportunity to organize the cables and wires in such a way that wasn’t so unsightly. Again, this was one of those balancing acts between perfection (which I typically strive for the best I am capable of) and just plain getting it done. I did accomplish something pretty neat (to me) though.
Here’s the best photo I could find to depict the previous rats nest on the driver side:
So the neat thing I did: I wanted to find a better spot for the two junction blocks on either side of the radiator. Somewhere out of the way, easier to mount (rather than trying to hold a wrench and nut on the inside of the fender), but not have to redo any wiring (so same general location). I started to think I was limited to the same spot on the fenders, until I discovered the underside of the core support. So I marked and drilled holes, then tack welded nuts over the holes and threaded automotive studs into the nuts. This is something I wish I had thought of when I had the core support on the bench (because welding upside down is not exactly easy), but, you know what they say about hindsight. My step-by-step photography game isn’t quite up to par either, but here’s what I got:
The nuts ended up slightly inward of the holes, which is causing the junction blocks to bow slightly. I may massage the mounting points in the blocks themselves to compensate.
Anyway, I also wanted the same ease of mounting with my starter relay for my manual glow plug control, but couldn’t really think of any better spot to put it than where I already had it, so that’s where I went to work. I actually really like this spot because it’s makes for easy maintenance access.
Careful examination of my welds will show that I am still quite the newbie, but I am learning.
Anyhow, with all of that set up, wire organization and cable management could commence. I know there are guys out there who could do this better, and I’d probably get shot at a car show, but again, there’s a balance that must be found. Not sure if I’ve found it. That headlight harness isn’t exactly doing me any favors.
And that is pretty much where she sits right now. Like I said, she’s in the last 10% and I probably need to take a break. Wife’s truck is going to get some treatment this week: new Bilsteins, Toyos, and a steering stabilizer. New headlights went on last week. As for Rusty, I am hunting down some plugs to cap off the radiator engine oil cooler, hope to have the PSC steering box back this week, need to paint and install the passenger front door, and need to install the harness for the trans cooler and a gauge for the engine oil cooler. Then, it should be ready to go to the shop for a frame straightening. Once that’s set, the inner fenders can go on, as well as, the grill and headlight bezels. Then to the alignment shop it goes and then back to Driveline Services of Jacksonville to get measured for a new front drive shaft. During and after all of that, it’ll be getting a surprise that I’m pretty excited about. Hint: it starts with a “B” and will better protect the truck from the next Honda that tries to kill it.
Till then.
Andy.
