Oh worst case he welds a bar on it and hits it with a ford universal tool, aka bfh.
That’s pretty much what the fourwheeler article suggested.
I just wanted to take a moment and thank the guys at Offroad Design for being so patient in answering my questions, as I have had a lot. It’s been a huge help as I have though through this build and how I want to go about it, making assumptions based on research, and them verifying said assumptions are correct.
ORD has awesome customer service.
You wear it well! Glad you’re digging it.
David
You'll never regret going lower with the gears. I debated between 4.10's and 4.56's when I did the axle swap on my Yukon, and I'm glad I went with the lower gears.
Went for a drive today, truck is idling high. From what I’m reading, looks like I might have a new passenger temp sensor in my future![]()
Have you directly tested this circuit yet? I.E., unplug the green wires on the IP or the temperature SWITCH (not sensor) in the passenger head and see if the idle goes back to normal speed.
Well, no, because we just got home!
But since you mentioned it, I yanked the plug off the temperature switch ( sorry for the incorrect terminology) and the engine immediately dropped back down to normal speed.
Ok, so you're confident that the temp switch is staying closed after the truck warms up. Sounds like a good place to start.
Remember that the switch is inserted into the water jacket, so coolant will gush out when you remove it. This isn't a problem as long as you quickly get the new switch into place.![]()
