Heres how my brain works when I see it all together. Roller on the top of the front bumper. Cree curved LED light bar above the windshield with a roller on it and a roller on the back bar. Done. Easy peazy.
Follow me for more ridiculous thoughts and ideas.
Looks good so far.
ATV winch for the win!
I like the ATV winch on the rack idea. I'll bet you can figure out other uses for that little winch too.
I think it will be the best option.
Not being critical in the least here, but man that seems to be a lot of effort needing to be done just to even open the back doors to get something.
I went through this with the temporary swing down tire Carrier we built for mine. Any time I needed something out of the back the tire has to go down. Then it's got to go back up. (yes I pulled out of the driveway at least once with it down) That's just normal use, running errands too. Factor in camping/wheeling and anytime I needed something it went down again.
I'm not saying scrap the design as it is well done. Plus I doubt a swing out style spindle can really hold the weight of a 40" wheel and tire combo.
But as often as you'll need to get in the back of the burb try to make it as simple as possible to handle the lower and lifting. Like when you to get the ATV winch set up, make sure at least the passenger side door can open clear of the cable you can get what you need quick and not have to always disconnect the cable to get the door open. Even if that means off setting the winch to clear.
I'm just throwing out the thought starters since the actuator didn't pan out.
I’ve gone back and forth with this A LOT. I’ve always loved how easy the barn doors were to access once I got the new ones on and functioning well.
But I’ve come to terms with the fact that sacrifices must be made when running these big tires, and it all comes down to what’s most important. For me, I’ve never liked how much space the spare takes up in the cargo area. I’ve always wanted to maintain the ability to haul 8 people, or a full stack of plywood. My goal for this truck has also been for it to be an all-purpose, over-landing, camping, rock-crawling rig. In short, I want to be able to sleep in it. We’ve tried that with the spare in the cargo area, and it was just too tight. My claustrophobia issues kicked into high gear big time.
So I figure, for me, easy access to the cargo area - in favor of increased cargo area - is an acceptable sacrifice.
I fully agree with you though, I need to do everything I can to make this easier. Atv winch. Yes. Offset. Yes. I’ve raised and lowered it a couple of times already and it’s a struggle.
