Last night was a blast, Firebird was sold out again. I did manage to be the first one to the lanes and one of the first down the track though. I got 4 runs in, which is about all a 10lb bottle will do for me.
For the first run, I didn't change anything, I just took it down the track and set a new PB for the truck,
[email protected].
I drove around and got right back into the lanes thinking I'd have 30 minutes or so before I ran again. I did not. I quickly made some changes to my tune to change the shift points (went from 5000RPM to 5500) and to set the torque converter to lock above 4500RPM in 3rd and 4th at WOT. I was rushing and barely finished before I went up to do my burnout and stage and I forgot to turn on the nitrous. I didn't bother uploading that video, it was high 13s at 99mph or something like that. I quickly drove around and got back in line for another run, this one was another PB,
[email protected].
After hot lapping 3 runs we took a break, grabbed some food and watched the racing for a while. We looked through the data logs to make sure everything was good and took it for one more run. Previously I had adjusted my nitrous heater switch to bump the pressure to 1000psi from 900, but for some reason it had just been heating to 900. During our break it finally pushed the pressure up to the correct setpoint. Since the new converter stalls at about 2800rpm when foot braking with this engine, the nitrous comes in pretty quickly after I let off the brake (3000RPM). The higher pressure lifted the front more than I've ever experienced with the truck, it fully extended the front suspension and may have picked up a tire, but unfortunately you can't see it on the video if it did
. New PB again
[email protected].
After the final run we went back to the stands and watched the racing for a bit before we headed home. It was a good night hanging out with other gearheads.
Here's a couple burnout pictures to cap off the evening.
We got home fairly late and crashed, when we went back out to check out the truck we realized we found the limit of the factory battery tie down...
We'll have to come up with something better for that.
We pulled the battery out and then got a bit carried away. It's hard to stop pulling parts out once you start
Now for the bad part, the driveshaft was vibrating at the top end of the track pretty badly, not as violent as the steel one, but it was definitely buzzing. The 275/40R17 drag radials make the driveshaft spin 20-25% faster than the street tires (275/55R17) and I think that was a big factor. At full droop the driveshaft was pretty close to the driveshaft loop/crossmember and I think the combination of the driveshaft vibrating, me getting on the brakes at 100mph+ and how close it was made the driveshaft hit the crossmember....
On the bright side, we're hoping to have the new engine in tomorrow. I need to make quite a few modifications to the wiring harness, fuel system, Nitrous setup etc. but the engine will be mounted in the engine bay tomorrow (fingers crossed)!
