Nothing here, just seen it before. Just saying all hobbies get expensive, involved, and frustrating.Please do tell.
Just in another thread we don't want to derail too much
That's a stainless braided line with a black sheath, there wouldn't be any thread in it that's not stainless. I went back and looked and whatever that is isn't there anymore.
Yeah I have a minimum 9am.
They Holley is a lot forgiving, it gets you in a good base but to iron it out it’s a lot of transfer or the up arrow on the keyboard.Can you see a desired PE lambda? What are your trims like when not in PE? If by applying learn to run table, and doing so without quite a bit of driving, then you could be filling it with data which is not stabilized. I.E. data which does not have enough counts in the cell to stabilize to a true trim. Steady state driving is key. Sure I don't know holley's system, but that is going to be the case for everything.
Also, if you are so rich you misfire the O2's can start reading lean as they are picking up the leftover oxygen.
Yes, I can see the desired lambda, on the last drive I specifically found spots where it was having trouble and did some datalogging there. It's compensating up to 19%. I need to do a bunch more driving, I just wish it was running better already.Can you see a desired PE lambda? What are your trims like when not in PE? If by applying learn to run table, and doing so without quite a bit of driving, then you could be filling it with data which is not stabilized. I.E. data which does not have enough counts in the cell to stabilize to a true trim. Steady state driving is key. Sure I don't know holley's system, but that is going to be the case for everything.
