Are you feeling confident you can make the next track night?
I had another long day in the shop yesterday, and no, I'm not confident, but I am going to try.
I finished up the H-pipe and got everything re-installed on the exhaust. Apparently I took a terrible picture.
We installed the throttle cable, got the truck started and let it get up to temperature per the break in instructions, then we took it for a short drive.
The tune is terrible, I need to do major work on it to make it driveable. It's so lean on startup, it won't re-start once it's warmed up. I think the pulse for the injector is so short it's not actually putting any fuel into the cylinder. If I start it on ether, it will idle, so the injectors are fine.
It also has an oil leak from the oil cooler block off plate. On the old engine I had an adapter bolted there that had my secondary oil pressure sender in it, but it was leaking so I put the one that came with the engine back on with a new gasket, still leaking...
Things left on the to-do list before next Friday:
- mount new slicks and see if they fit (I ordered a set of Hoosier BDR 28/10.5R17 tires to get my driveshaft speed down, old tires are 25.6" diameter)
- Speaking of the driveshaft, I need to do something about that. The plan was to drive it to the driveshaft shop to have them look at it and see what they can figure out, but it needs to be driveable first, this is one of the items that may make me miss next Friday.
- Make a mounting bracket for the catch can, make and run hoses for the catch can
- Fix the oil leak
- Wire the flex fuel sensor to the ECU
- Wire the N2O solid state relay to the ECU
- Make the rest of the -6 Nitrous line and install it.
- Fill the nitrous bottles
- Charge the A/C (it's hot here already)
- Engine break-in. I need to drive it 200 miles and change the oil.
- Spark plugs. I need to figure out what plugs to run and get those installed. I'm currently just running the same plugs as before (1 step cooler) because I had them.
- Tuning. I was hoping to get to a tuner, but I don't think that's going to happen so I have to figure the tune out. This is the other item that may make it so I miss next week. I can't even do the break in on the tune it has now, it's so lean it's popping and banging when I roll onto the throttle. I need to get that figured out ASAP, but I have to finish a few other things on the list before I can do that.
- Re-install the hood.
Thay have track in summer? If not this mifht be last till fall
There is a drift and DRAG event on May 3rd that I may be able to do, I'm not sure how that works though. They don't have anything else posted for the track in the summer, but I'm not sure if they'll add something later.
