Thanks, I have a tendency to over build. Glad to see quarter inch plate is strong enough without direct frame underneath. I need to redo the decking on my equipment trailer. May be a good time to integrate into it for heavy jobs
Yes, that was the issue, I wanted the bars to be parallel to the ground at ride height and all of those kits are designed for the truck to lay frame and ride way lower than I will be.Surprised you didn’t find a link kit you liked. The only thing I can come up with is, most of them have a big c notch and would cut into the bed making it useless.
Does a drag strip count? I will likely need to add a sway bar in the rear, but I'll wait until I get on the road to determine that. The QA1 bar in the front is 1 3/8" so that will be nice, and the airbag system will have height sensors so it can actively keep it level, but I doubt that would be quick enough to be effective on a course.If this thing doesn't run at least one course somewhere, with video, I will be very disappointed.
Top notch work as always.
I have been a firm supporter of the Watts Link system for a long time. Most builders don't want to put in the effort. I think it is just as easy as a panhard, just more time. And better results.
so you'll have to wait to see that. We mounted the control panel right on the center console next to the shifter so it's easy access.
