That stack looks great. Nice job fitting it all in there.
I've seen that stuff before, but I believe it has to be put on the inside as it's a water based thing. It wouldn't hold up to the elements.I have never used it but this stuff is fire rated. https://lizardskin.com/heat-protection/
You can use it on the inside if you're looking for the heat/sound dampening aspect. You've got your interior out, perfect time.Dang it was on my list of stuff to use, back to the drawing board.
Just don’t do what I did and plug holes you need.I did, intentionally because I'm changing up the wiring routing and a few other things.Just don’t do what I did and plug holes you need.
It was clean before can’t wait to see it next.I did, intentionally because I'm changing up the wiring routing and a few other things.
If I do it right, there won't be much to see.It was clean before can’t wait to see it next.
