The Shop Truck
Nice catch on the street sign!
also Clydes is the best burger joint in da UP!
As mentioned, this tuning is outer space for me, but if I keep reading it long enough maybe this old dog can learn something!
That's kind of crazy, all my pressure and temp sensors are from almost 10 years ago now, all Holley.
I had a IAC vibrate loose, I used loctite on it after that.
The only sensor I have had go bad was an O2 sensor, but that was pretty much right away because the self learning added 100% fuel at low RPM and flooded it before I learned to limit/correct that.
Now that I said that they will probably start failing one after the other.
Well, I just hooked the sensor back up to do some testing and it's working fine. I reinstalled it and everything looks good now. I'm wondering if I got some water in the connector when we washed the engine bay in Michigan and that was causing the bad reading.
Unfortunately we've had too much going on, plus I didn't get all the parts I needed ordered. There's no way we're going to make the 19th. The next one will the week after on the 25th, so hopefully we're good for that one.
I finally got a chance to do a little work on the truck this afternoon. I swapped the even and odd injectors, swapped #6 and #8 EGT probes, and swapped #6 and #4 spark plugs.
While I didn't get the huge dip in EGT temps on #5 like I saw when the injector was in #6, it was the coldest hole when under heavy load. It was hardly noticeable at all with the big pulley in, I had to put the smaller one on to get it to show up at all.
The white line is #5, #6 is one of the pink lines. By the end of the pull it's the lowest temp, but the entire spread from hottest to coldest is only 100°F. If you look at the graph from before I swapped injectors around #6 was 300°F cooler at the worst point.
I have a cheapy fuel injector cleaner rig, I may pump some washer fluid through all of these and just run them at the next test and tune. If the issue comes back, I'll stop, but I need to get out and test the transmission, fuel injectors and new driveshaft (once I get it).
I finally got some time to drop the pan, I'm a little concerned about the amount of clutch material in the pan, but it does have around 5000 miles on it I think, not to mention 30 or so drag passes.
What do you guys think? I'm not an auto expert for sure. There was also about a 1/4" ball of metal material on the magnetic drain plug.
The fluid looks great, if this is the first pan drop since the build, I wouldn’t be overly concerned about the clutch material and I’d say button it up and run it….however the ball of steel debris may be concerning. It could be steel plate or (torrington) bearing material. Call your builder to be sure.
I already sent the picture to gearstar and told them the same thing. I'm just waiting to hear back from them. I ordered a bench mount so I can tear into it better, it should be here tomorrow. The trans brake showed up on Saturday, but I still have a few things I need to order to get it back installed. I'm hoping I can have it back together and tested in time for the Friday Night Drags on the 25th.
Are you saying that you found a 1/4" of metal shavings on the magnet or chunks of a 1/4" metal ball?
I'm looking at it like "I'm already going to have it apart, do I replace the clutches while I'm in there?" But I think it will be fine once I get the pressure issue fixed, assuming that's the problem. I have to run a deep pan to clear the solenoids, so I ordered the B&M one that adds 3 quarts and extends the filter down. That should fix any pressure issues I have.
I'm pretty sure I found the issue. When I dropped the pan I noticed that the entire bullet at the end of my dipstick was below the gasket mating surface. According to what I'm finding online, the "full" mark should be 1/8" to 1/4" above the mating surface, so I was probably an inch or more low on fluid. It seems to be a common issue with the Lokar dipsticks.
Thankfully the cable is attached with a set screw, so I should be able to remove it from the handle and shorten it so it's reading properly.
Gearstar did get back to me this morning, they think I should pull it apart and look at the clutches. I'm not sure how hard that is or if I need any special tools, but at this point if I can look at them fairly easy while I have it apart, I will. If not, it's going back together with the clutches that are in there. Outside of launching hard on the drag strip the transmission shifts quickly and firmly, so I don't think it's hurt too bad.
