The parking brake cables on the 14FF were not going to work with the lift and the '72 brackets. I need to address this issue because I need a parking brake. The pinion seal has needed replacing for many years and I need to swap the original G80 Gov-Lock unit for an open carrier with a Detroit Locker in it. I guess it is time to tear into the rear axle.
I was glad to see the ring and pinion were in fantastic shape. The backlash was in spec, so no need to replace them. I pulled the carrier out and was going to go after the pinion seal. I was going to check the pinion preload, but decided against it because it woud have been a waste of time. There was some, but nowhere near enough to bother checking. Luckily, I had enough foresight to realize this would probably be the case and I had all the pinion bearings on hand. As I was pulling the pinion support out, the UPS dude showed up with my two crush sleeves and shim kit. I always have two crush sleeves on hand so I can get the preload right the first time. I found out years ago that if I have only one, I go past the specified preload and have to go get another crush sleeve. I got the pinion support assembled and installed. I got the Detroit installed, set the backlash and sealed it up.
