Always wanted to hot rod one - you show off the motor upgrade one on here?
Just got motor for it a few months ago . Its in the pile of goodys to build . The warn XP guys use is 6hp and same basic price of the bow 2 6.8hp .Always wanted to hot rod one - you show off the motor upgrade one on here?
@sweetk30
Did you ever install get an Albright solenoid installed on one of the Ramsey winches?
nope not yet . . . but i have collected more winches . . . winter project this season for sure as theHolmes 220 single line will be going onproject budget beater and i plan to have some winches on it .Is it possible to rotate the worm as gentle persuasion is applied to the shaft that the brass gear drives - and after it’s removed deal with the worm gear assembly since it will be free from the continuous gear contact resistance at that point ?I'm converting a Ramsey 7" drum to a 12" drum. Using a 12"drum pto as the donor.
I'm not having any luck getting this apart the rest of the way.
Anyone have any experience that could help me out?
It appears there should be a snap ring behind the input shaft bearing but not having any luck removing the bearing. The big {brass}? gear does not want to come out either.
I have tried that but will be giving it another shot today.Is it possible to rotate the worm as gentle persuasion is applied to the shaft that the brass gear drives
FIFYInput worm the bearings are just pressed in . It is no fun at all to get out .
