The Willomet Charger
A desecration to Mopar nuts everywhere, this is my protouring, LS-powered, 1970 Dodge Charger; built at my shop, Willomet Motor & Fabrication.
Side benefit of the Hobart dropping another potentiometer, lots of time on the TIG machine.
Didn’t quite make my progress goal tonight, but I’m planning on hitting it early tomorrow before work.
David
It was a longish weekend (and early Monday) of details. I pulled a half day on Friday, and I still didn’t make my goal of getting the front rails “done.”
I underestimated the time required to juggle some kitchen renovation tasks alongside car fab. Also, the Hobart’s new potentiometer died, and so I ended up TIG’ing a lot more than I planned, and while I like the practice and learned a lot, it’s a substantially slower process.
Outer plate burned in
Inner plate ready to tack
Lots and lots of blending original shapes to match the new overlay plates. The original steel doesn’t weld nearly as nicely as new A500 plate, so I’ve got to be careful with the current input and use a slight weave to maintain a consistent puddle.
This gobbles up the hours, but the result is worthwhile
I had some pretty radical tungsten stick-out to get to those corner welds
More time tonight, and now that the front plate details are complete, I just need to start fitting the top plates and get the rear plates tacked.
Closing in.
David
Copy, and paste.
Passenger rail is welded internally and tacked externally. I’m planning to close up those open corner welds tonight and tomorrow. Parts for the MIG should arrive tomorrow, and I prefer to use that machine for plug welds.
I’m not yet a strong out-of-position TIG welder, so I’m leaving the overlay triangle welds until I can get the car on the rotisserie...unless I get brave.
David
I assume from your spacing and corners these will all be ground down smooth like?
Looks good man
Yeah, I’ll lightly blend these. I’m always concerned about taking away too much filler material. I usually just level each face, and slide the DA over the bead itself.
David
Non-dominant hand welding - got some practice on that, too.
I’m adjusting the settings for today. Looking at slightly hotter, but shorter bursts. Part of the problem on the heat input is dwell time, and I’m experimenting with some scrap first. Starting with 95A, 30% time on, 35% amps, 0.2 Hz.
David
I’ve never pulsed, learned from a old school guy and never had a need to try any other way.
And my 351 sycrowave doesn’t have the option. Haha
If I was welding that with my machine, I’d have a 3/32 tungesten, 90-100 Amps. Expecting to be 40-50% pedal. Acquire my puddle, watch for the bright dot of carbon on the leading edge and run my bead.
Control arms are single pass, no pulse.
Subframe to frame connector brackets have a root pass and a finish pass. Again no pulse, just running a bead
I’ll
... I’d have a 3/32 tungesten, 90-100 Amps. Expecting to be 40-50% pedal. Acquire my puddle, watch for the bright dot of carbon on the leading edge and run my bead...
Very good looking work. Notes taken.
David
Spent the early morning finishing welding the overlay plate. I still have to do the other side, but that will have to wait for several weeks.
The Charger build is idled while I turn my attention and time to suburban prep in advance of its next adventure.
I know exactly where I have to start - finish weld the other overlay plate and start building the floor support structure. If you look closely, you’ll see that 3x1 steel for the floor stored inside the car.
David
