This is why I went with the LS in my truck. Btw it revs to 7,000 with no fancy stuff and you have heard it.
That's one aggressive plan, I like your style!Some of this is driven by my persistence for an aluminum block, LS7 top end, 8000 RPM rev limit for shifts at 7500, and 100,000+ mile longevity (probably getting 600 to the wheel). TSP requested a 5.3 Gen 4 block for a 427 build, which at 4.125x4 is a majority of what they build and has a wide range of use cases. I grabbed the LC9 knowing it didn't limit my options, and was pretty cheap on Marketplace and in good shape. There's no ridge on the liners.
Candidly, I don't actually care about the displacement. A 383 would let me troll just as well as a 440 or 426, and like I said earlier, I'm willing to fudge the details for the proper effect among those cube-sensitive die-hards. Real priorities for the engine are:
Related, the rear end is 4.11, and the ratios in the magnum are 2.66, 1.78, 1.30, 1:1, .80, .63.
- Reliable delivery of 600 whp for 100,000 miles
- Aluminum block (saves 100 lbs over the LQ4 iron placeholder)
- Use as many off the shelf components as possible - avoid custom pistons, specifically
- Smooth and snappy throttle response - 8CCW crank, lightweight rods, lightweight flywheel, etc.
- High red line with 7500 upshifts
- LS7 dry sump
- LS7 Harrop intake
- Tunable for 91 and 93, and maybe a "track tune" for fancy fuel
If you would, DM me your phone number and let's have a chat. I'm soaking up as much info as I can and welcome any insight you might offer.
David
There's definitely the sloppy mechanic crowd that will drag race turbo motors on stock bottom end engines and shift in the 7500-8k range with regular hydraulic lifters.....
....it's not a sustainable model and you're definitely not getting 100k Miles.....a lot of these guys end up eating motors anyway....everyone said it wouldn't work....
I'd stay in the 4.0 stroke for sure.
During all my research for mine it seemed like a hit or miss above that. Some guys can run a 4+ hard for years, and be fine other guys have piston issues constantly.
I did see that Wiseco seemed to have the pistons nailed down for the longer stroke stuff (4+). And most people agreed with that when it was stated.
Wrist pin location and ring placement gets odd in the real long stuff.
Wow! Sounds like a recipe that one might ctrl+c and ctrl+v.I have a 427 ls3 in my nova. Not running yet but dynoed 680hp at 7500 at westech. I had tony mamo from mamo motorsports build it with his complete topend. It sounded amazing reving up. With my tkx trans, carbon driveshaft, rps twin carbon clutch and gundrilled axles in the 9" floater im expecting just under 600 to the tires
let me dig up the build sheet. this engine was built 5 years ago. im really slow on this build. my suburban has been much faster. it started with a texas speed short block that i got on a black friday deal. i then had Tony assemble with his top end. He was the top guy at afr before going out on his own. he has a ton of builds on ls1tech especially on the corvette forum. his write up on my engine is under small bore 427 under the dyno section.Wow! Sounds like a recipe that one might ctrl+c and ctrl+v.
Do you have a more detailed breakdown?
David
You're going to hurt some feelings, not mine, but someones.Scored a clean ally block for the final engine. The general doesn’t make these anymore, and I don’t need a concept performance block. This LC9 will take a resleeve very nicely, and become a 427.
I’ll round down to 426 for the Mopar folk.
David
Yeah. Some folks are pretty tender-hearted about this stuff. There’s a b-body forum that has me all but black listed.You're going to hurt some feelings, not mine, but someones.
Really appreciate this kind of experience being shared. It helps me maintain perspective on what’s important - building a car that’s fun and fast, and having reasonable expectations for how many horsepressures I need to do that.Then again I've seen a 70 HP swing just changing tires on a chassis dyno, due to tire weight alone
That sounds amazing, I wish I knew how to find that cam.Found the build sheet. It made peak power at 7250 and shift point is 7500. I was a little off.
Mms 260cc ls3 heads
12:1 compression for 93 octane
Ported mid runner fast 102
243/254 114+3 cam
Limited travel hydraulic lifters
Yella terra 1.7 rockers
Manton pushrods. Cant find the original dyno vid but heres a link to my Facebook post of it
That cam by itself won't work well with your heads or converter, or stroke, or vehicle combo Ben. It's also probably going to have more "chop" than your rattler cam but because of the duration, not the LSA.That sounds amazing, I wish I knew how to find that cam.
- LS7 Harrop intake
