Damnit once again Rene beat me to a post and said pretty much exactly what I want to say.
I had a th350 in my K5 and swapped it out to an SM465 and was immediately in love with it. Now I never have the thought "what if my tranny goes tits up out on the trail" Just not something you have to think about with a 465. I like the torque multiplication of a torque converter, just keep mashing the pedal down and it keeps adding power, but its even cooler to just throw it in gear, let out the clutch and idle along. I swapped out my 350 gasser for a 6.2 diesel. In high range with 39 inch boggers I can throw the 465 in first and idle over most trail obstacles without ever touching the throttle.
The last straw with my th350 was when I tore a transmission line on the trail and spewed ATF all over my exaust manifolds and the transmission quit pulling. I thought damnit im going to put a transmission in here that dosn't need a hydraulic pump to build pressure to make it go.
Why SM465s rule by Robert79k5
1. Dosn't require a cooler
2. dosn't reqire lines to run from a cooler to the transmission.
3. will still drive the vehicle even without a drop of fluid in it.
4. more efficient as mechanical energy isnt converted to heat in a torque converter because there is no torque converter.
5. Flat out tougher... no clutch packs or pumps to wear out.
6. Simplier.. no valve bodies, filters, solonoids, throttle cables, plungers, check valves etc...
7. If the unthinkable happens and your SM465 does go haywire out on the trail you can just unbolt the top, pull the shifter/fork assembly out and pretty much get to everything you need right there in the truck. you can even shift it with a screw driver if you need to.
Whats funny is I decided to fix up the Blazer and make it nice so now im building a lightweight trail beater and its going to run a TH350 auto. But thats a story for another thread.
