and so ends the 6500 miles of service i got from the used TBI350 i just put in the blazer??
-edit-
video/audio
-edit-
video/audio
nah - warranty shwarranty.Damn that sucks. I just put a rebuilt 350 TBI in one of my rigs. Was a little worried I had a lifter tick but it went away after some adjustment.
Where did you get your engine and does it have any warranty?
who's there??Knock knock...
Well I feel your pain. I'm on engine #6 on my 87 K5. Some I was not happy with, some went bad due to mistakes.nah - warranty shwarranty.
hard to complain for 400 bucks-most people seem to want 1500 bucks for condition unknown.
was a worthy gamble with 120K on it, and had great oil pressure and compression right up to the end.
it allowed me to pull my engine out intact, and get the truck smogged and tagged again.
which shop was this?Well I feel your pain. I'm on engine #6 on my 87 K5. Some I was not happy with, some went bad due to mistakes.
stock 350 - needs more power!
built 383 - lost due to oil pick up tube falling out and no gauge
used 454 - lost its bearings, probably due to improper cleaning of block/heads
crate 454- Horrible power, 190hp at the wheels due to shitty heads
built 496 - great power, lost in Moab due to bad machine work
built 406 - so far so good... knock on wood...
These days I prefer to have a GOOD machine shop build my short blocks since they measure and double check all the tolerances and make sure things are within spec including magnaflux the block along with line bore. Any time I have tried to skimp on good machine work costs, it always bites me in the ass. For example the cheap machine shop I had build my 496. They really screwed it up and it lost all its bearings and damaged the high end crank.
Western engine. Should have went to Colorado Custom Cylinder Heads or theres a few others up North. Geddes in the springs is good too.which shop was this?
the initial few days of ticking/knocking made no difference to the oil pressure or the way it ran. idled smooth! -oil pressure was great- low 30s at idle, and would come up to mid 40s at higher rpm ranges.I was gonna say rod #5, but sounds like something else let go
kept oil pressure until it locked up?
AHHHHHHHHH!!! thats what killed the first engine in mine! going down a long sandy hill that was so steep that teh back end would come around if you let off the gas - cant roll down that hill - have to DRIVE down it, and alternate on getting on the brakes when possible to try and slow down a little as best you can...Well I feel your pain. I'm on engine #6 on my 87 K5. Some I was not happy with, some went bad due to mistakes.
That's kinda creepy. Like Christine creepy. Get it home, pull the oil filter see what's in there and maybe get one of those small flexible cameras for your cellphone. Either that or just pull the engine and start your rebuild while it might still be salvageable. Reconditioned crank at Vatozone for sbc400 is 350 right now. Rockauto was out of stock. TBI350 might be different. It sounds like a bearing locked up, partially shrapnelled, and then decided to start working again. In which case, that's not exactly good for longevity.the initial few days of ticking/knocking made no difference to the oil pressure or the way it ran. idled smooth! -oil pressure was great- low 30s at idle, and would come up to mid 40s at higher rpm ranges.
even after the insides started coming apart in the driveway, the truck was still running, but having a hard time idling, was loping and stumbling, and had that nice metal on metal screeching from hell, and it still had 20-ish psi of oil pressure. I shut it off before something could come loose and out the side of the block - did not want a huge mess in my friend's driveway!
also, stopping it there -I had hoped to save it's last breath in case it needs to die helping itself on to a trailer...
funny thing is: its still in front of my buddy's house. he had to move it for street sweeping this morning, and he said it started and idled like normal??? It was quiet- no knocking and screeching like the other night - WTF?
He said he was afraid to rev it up, and just used the low gear and let the truck idle up onto the lawn until the street sweeper was gone, and then later idled back out onto the street with no problems. weird.
lol.Who’s there?
Rod
