TnA's 86 Jimmy Shop Build / Product Development Thread - (Trailing Arms?!?!)
Thats a cool roll bar idea!!!!
And im glad to help you get into the "never put the topper back on" sickness :thumb:
Its 100% more fun with the top off.
More of a full concept now... All still CAD drawings, but the dimensions are much more accurate. Also, the angles are set now to match the cab better. I'm thinking I might just have to make one to see how it looks on the truck. Maybe.
I would like to use that in my pickup. Put me down for one. :D
Final CAD model! I had to update the "feet" so they would clear the step-up in the Jimmy. Glad I saw that before I went ahead and started making the prototype!
When I get the prototype mocked up, you should bring your truck over so we can see how it fits the pickup bed!
Let me know. [emoji3]
I would like to put it at the front of the bed like a headache rack. And it looks like this will fit between the bed rails and tool box.
Made lots of progress today, awfully tired now though. After over 12 hours, I think I've come a long way, but there's still a ton left to do.
I got the major parts tacked together and was able to get it into the Jimmy for a test fit. The test fit went very well, so I took it back out and started to add the first tube to it. The whole thing still needs a couple filler plates and to be fully welded, that's gonna take some time! Anyways, I'm stoked with how it is coming out!
Now for the hour long drive home, eat, shower, and bed!!!
-Darren
That is cool!
Don't forget to do something to keep the ash trays from causing a rattle before final install.
That looks awesome! How did you figure out the curvature of the roof line?
Nice, a piece of flat plate that goes forward and goes under the lower seat bely hole would tie it in nicely.
Almost wish my burb was a "blazer" convertible, that is beautiful. Hope it lines up nicely with the truck cabs.
That is cool!
Lol, I was thinking I should have cut a "speed hole" right there so the ash trays could still be used. But then I thought that was ridiculous - the first thing anyone is going to do (or should do at least) after taking the top off semi-permanently, is to take the factory panels off and either replace them with custom waterproof stuff or just bedline the bed. The latter is my plan very soon.
Lots and lots, and lots and lots of measuring! I took a straight edge and ran it across the bed rails, then measured up to the cab every inch across. When I got to the sides, I made a vertical straight edge, and measured out to the sides up every inch. Then I put all those points into a sketch in Solidworks, and created a spline that matched as closely to those points as I could get it. That's the easy part. Since I know you know CAD, I'll tell you that getting that curve onto two different angled flat pieces, and then creating the top and bottom "shells" to wrap around that you can still "flat pattern" out to be cut on the CNC is NOT EASY!!!!!!!!!!!!!!!!! I think I've got enough hours just in the CAD model to make this thing not worth building already - and I've got some issues with it still that I'm not sure I can work out, I may have to re-draw a few parts of it to get them to work correctly in the computer. PITA!!!!!!!!!!!!!!!!!!!!!!!
Will it bolt to the cab on top?
Martin
No, it does not bolt to the cab, however it does butt up against the cab seal so if someone was inclined to make a soft top, it could be pretty water tight. The reason is that the main "hoop" will be fully welded and sealed from the elements. Running bolts through it will only make for a pathway for rust to start from the inside out. Also, those bolts are fairly small, and would only really function to stiffen up the cab, not give the roll bar and real added strength. My plan is to run an internal cage in the cab and tie into the roll bar in the future, so cab strength isn't going to be an issue. I don't really think there will be any movement between the two to create "squeaks" but that is the only thing I am concerned about, so testing will be done at BB15!
It looks like a great Segway to a pickup/cab conversion for the K5!
Yeah, I didn't think of that until I had it in the truck and was taking the pics. It would be really easy for someone to graft the back of a pickup cab with window into this, or create their own. I was thinking of having a soft top made to go over this and the tubework yet to be added, but a bolt-in hard back with a window might be a good idea too, and I could make that myself and not rely on some else to make the soft top. I'm decent making metal do what I want, but sewing and getting soft fabric to line up where it should is a mystery to me!
Ok, was messing around with ideas for the rest of the tube work this morning. Forgive my amazing photo editing skills, but here are a couple ideas I had. I'll also post the base picture in case any of you want to make your own designs for me to look at (please do!).
Base Pic:
First option, I like because it would give me the option to still keep the rear seat and carry passengers:
Second option, I like the look much better but if passengers were in the rear, they might lose their heads:
Any other ideas?
