destinbeachman
Kimber 45 CDP and AR 15.Full of mojo!
tch777 said:357 mag has 448 ft/lbs at 50 yds with a 170 grain bullet
40 has 413 ft/lbs at 50 yds with a 155 grain bullet
10mm has 452 ft/lbs at 50 yds with a 180 grain bullet.
41 mag has 630 ft/lbs at 50 yds with a 210 grain bullet
44 mag has 839 ft/lbs at 50 yds with a 240 grain bullet
454 Casull has 1470 ft/lbs at 50 yds with a 260 grain bullet.
3 on the tree said:Anybody know the ME on a 12 gauge slug??? Just curious.![]()
FreedomIsntFree said:Go big or go home right?
500 S&W has 2409 ft/lbs at 50 yards with a 400 grain bullet. I shot a few .500 rounds out of the 5" S&W revolver. I thought I broke my damn wrist!
odoa3 said:I agree with Jekbrown. research your ammo. For the .44 mag- check out the 265 grain Barne's Solids. I examined one that was pulled out of a brown bear that was shot in self defense- hardly deformed at all. Other than a small downslope on one edge of the bullet you would not have thought it had been shot. I don't remember what the bullet is made of for sure, but I want to say bronze. I love shooting large, magnum handguns but I only shot one of these and was done. However, in a emergency situation you will not notice the recoil, just the results.
rcurrier44 said:If you are realy looking for a defensive bear gun it would be better to look at the enegy at the muzzle for 2 reasons.
Unless you are walking around with it in your hand all the time you'll be lucky to get it out and armed before the bear gets to you. Most bears don't like to be around you just like you don't like to be around them...you are both deadly. Every bear (black or griz) I have run into have herd/smelled me before I saw them and were moving off. Most bad encounters around here are because neather the bear or the person knew the other was there untill they were right on top of eachother...a bear moves ALOT faster than you do.
The other is if you do shoot a grizly at 50 yards (or even 50 feet) you are most likely going to jail, will loose that powerfull gun, the truck you drove in there with and alot of $. At 50 feet thats poaching a protected species. That bear has to be so close that it can almost touch you. I think the average stoping distance for a bluff charge is around 20 feet...so I would think that to legaly shoot a griz he should be closer than that.![]()
