Could have used your help on Trifecta, I was the only one that "knew" the way out
Could have used your help on Trifecta, I was the only one that "knew" the way out![]()
The problem with the "trifecta" is that everyone who has run it enough to lead, is smart enough not to lead a group of 10+ people that are on slickrock for the first time.
I've only been to Blazer Bash 2x's, I've run Trifecta both times, and I think we need to limit the # of trucks in each group. Maybe even put like trucks together for the run. Having a truck with 33"-35" following a nut with 39"-44" tires, tends to end with the smaller rig breaking.
That being said, I'll probably run it again next year. It would be fun to leave early, finish the trail, have dinner, then do a rescue run for the newbies.![]()
I think all of us came into the trail knowing full well it was going to take us forever.
I did not think that it was all that bad of a run. Yeah it took forever, yeah we had a ton of breakage. We all decided as a group on what we were doing. I got a ton of walking in which was rather good for my MS so being the cripple I did not mind.
I love running the trifecta and I missed it this year. Part of the problem is that nobody wants to be the bad guy (talking about trail leaders). There are rigs that shouldn't go on the run, but nobody wants to say "you can't go".
I led the Pritchett run on Sunday, it says right in the rules "2 lockers, 38+ tires and winch required" 3 of 5 rigs didn't have winches, 2 were on 37s, but none of the issues had anything to do with those requirements, however if we would have excluded the rigs that didn't meet the minimum requirements we wouldn't have had any problems and probably would have come off the trail early in the afternoon (but it would have just been the two 1st Gen Brent's). We also ran Behind the Rocks backwards for reference.
I'm not immune to breakage either. I broke a main leaf on Green Day on Saturday. If that happened out in the middle of nowhere on the trifecta run, it would have made for a long day. A small break (axle shaft, drive shaft etc.) on the Trifecta makes for an extremely difficult recovery.
