So you need to find someone to turn a 1.500 Acme thread for you? I could probably find someone up here to do that, but the logistics of it may make it prohibitive.
No, the shaft is a 1.500-5 acme threaded shaft. I need one end turned down to .999 to 1.000, to fit in that tapered roller bearing, X 3.00 back from the end. Then 1.375 of that length from the end threaded with 1-14 standard fine thread with a class 2 fit or better is fine. Standard chamfer on the end for a 1.0 thread. Fillet rad @ the 3.0 face .030 max. The 1.0 diameter must be concentric as close as possible to the 1.500 shaft itself, and the surface finish has to be pretty nice since it's a bearing diameter. The OD of the 1.500 shaft is a really nicely machined finish and must be protected and not dinged or mashed or marred.
On the other end I want a standard 1 1/4 hex machined to drive it, machined about 7/8 to 1 inch in length. I can actually get that done myself. It's mainly the lathe work I can't do. I just figured if I have a shop do it, might as well have them just complete both ends. Thas it. Pretty simple job I could do in my sleep if I had the right equipment. I actually have one 24 inch length of shaft but I can cut it in two and only need one 12" shaft machined up. Thats it. Easy job to do. It's just all the shops don't want to do such a small job.
. Hell I think I've certainly earned it based on that.
