I'd like to see the results at each step, it's always good knowledge to see what changes do to data! You have an AutoProm like me so should be able to tell pretty fast!
I assume I should be tuning for long term.
This is at 113 BPW
Also, what is the correct way to turn off the EGR?
I turn off the EGR by setting the the Minimum Speed for EGR ON to 255 MPH, and Minimum Speed for EGR OFF to 248 MPH. I also set the temperature EGR ON to Max 151 C, and Temperature EGR OFF to 146C.
If I had a histogram look like the ones posted, I would INCREASE the Injector Flow +2 lb / hr. Example old Injector Flow =61 lb / hr. ~ new Injector Flow =63 lb / hr.
dave w
dave w
I never even thought of doing that!
Would it be possible to see a screen shot post of the VE tables?
Ideally, VE numbers should be more than 45 and less than 95.
dave w
You probably already know this, but for someone new to tuning it's worth mentioning. The BPW is a course adjustment, and the VE table is a fine adjustment.
I tend to adjust the BPW so that the histogram shows some cells rich, and some cells lean.
dave w
I didn't see dav w post when I did must have been the same time.You probably already know this, but for someone new to tuning it's worth mentioning. The BPW is a course adjustment, and the VE table is a fine adjustment.
dave w
. I usually wait on WOT tuning till I get the majority of the VE Table figured out.
Exactly! You could raise WOT cells to 95 and if it does not go lean your OK with BPW you came up with.Yeah, I was ok with that until saw WOT go lean. I'm under the assumption that the BPW should not go so low that it allows lean at WOT.![]()
