Anyone have a listing on a 14 or 16 PSI spring?
That's as low as the spring will go even with adjustable regulator? If you have an adjustable regulator you could put a stock spring back in, I don't know how far a stock spring will go but I know for sure it will hit 16 PSI, maybe more...
There's always more than one way to skin a cat! I like K.I.S.S.!
Once you start changing fuel pressure there are other things to consider like Injector Bias measured in milliseconds like 0.396 and then AE and PE and probably things we don't even know of? It's like the ECM can adjust itself right? Well how come we have to tune it then? Because it can only go so far, it was only designed for a certain range!
If you stay close to 13 then your in the KISS. I just used the injector sizing excel spread sheet for a 383 with 90 pound injectors at 18 PSI and that would support 424 HP with a BPW of 88.1... pretty big change in BPW and I'm not sure of all the consequences... plus your motor is probably closer to 350 HP.
Now at 13 PSI on your 90 pound injectors will support 360 HP at a BPW of 103.7 so your a lot closer to stock BPW and have plenty of room to go up to? What was yours? 126? I've found the spread sheet to be a little on the low side for BPW... so at 13 PSI you may be spot on.
Plus of all the mail order chips available you have one from a guy who has done this a long time and has a great reputation. So if you gave him all the correct specs to begin with then your chip is probably real close and only God could tune it better by mail!
Just my .02 cents...
Link to injector sizing spreadsheet.
http://eagle-mark.com/pictures/displayimage.php?pid=1188
So a long time professinal tuner just varified what I told you?
Wish I had an extra spring to send you, just looked...
But my question is will the duty cycle on those injectors be ok or should I really be chasing down some 65 lbs injectors and a 14 psi spring. I guess the stock spring wont be that hard to source but I'd rather not go through changing it twice if I do not have to.
I was thinking if a 14 psi spring and a set of 65 lb injectors would get me a BPW a little higher then 103 I might be better off.![]()
Stock spring will be fine and go to 15 or 16 PSI, I forget. You;ll probably be good at 13.
Why waste time and money trying to find RARE injectors that people have been snatching up for years? They are only 4 pounds difference.
I was hoping to be able to post an update, but without the new spring I really can't do much.
I have looked at a lot of stock fueling tables and they are not smooth. You should smooth transitions some but NON stock motors have way different power bands than a stock engine which has a smooth power band and GM still did not have smooth fuel tables.Did a 20 minute ride on the new spring; pressure is right at 13 psi now.
As you can see I have a lean condition that starts at 70 kpa. I could probably tune that better in the VE table but when you look at how big a change it will be from the 60 kpa the difference is pretty big.
I was under the impression that you wanted a smooth table.
No. You need to get all cruise data, like under 70% TPS correct first. I am not familiar with $85 so you will have to look and see where WOT is? Or when PE comes in? Stay away from there until fuel is correct, then work up. WOT is an adjustment based off these numbers.While watching the histogram build the data I would say 90% of all the lean hits happen between 50 and 100% TPS. The lower TPS hits are when above 65 mph and on the highway.
I assume this indicates a need to adjust the WOT to AFR table.
Lower number = richer.Is a higher or lower number more fuel? IE 14.7 is leaner then 13.5 or is it the other way around?
I assume this indicates a need to adjust the WOT to AFR table. Is a higher or lower number more fuel? IE 14.7 is leaner then 13.5 or is it the other way around?
Well if they are 90lb injectors, which I have never seen? Then injector sizing chart says 103.7 BPW. So 105 seems like a good start.
But if they are 80lb, the biggest made by GM, then at 13 PSI and 95% duty cycle you would need BPW of 116.6 to supply 338HP.
I would go 120 BPW to keep WOT under 95% duty cycle, then tune VE.
HTH!![]()
