Turbo 400 disassembly
Here is a video that makes it look like your pump is in all the way.
Also went back and zoomed in on disassembly pic and it’s right
Just my paranoid ass….
The endplay should tell you, if its not all the way down the input shaft should have excessive endplay.
And if something is wrong or binding it might have zero endplay and you couldn't turn it.
Same with the output shaft.
And it does spin
What specs are endpaly on front and rear of trans? I am way too hot and my brain is fried…
Next is valve body but that will have to be tomorrow night or Friday, mom has surgery in the morning
it was col when i air checked toe clutches ,they held .
i is happy......hope like hell this works well............
There will be some kind of bugs to work out...there always is on a project like this. Just have to take short drives at first, in order that if it does break down you are within walking distance of home. Then little farther away, and then a little farther away then that, until you are confident all the bugs are worked out.
