k20
3/4 ton status
Ok here goes, I had a 4" BDS lift, 1" zero rates, and 2" longer shackles in the front (1" of lift) so I had a total of 6" of lift up front. To correct this I had a raised steering arm (this is stock pushpull crap). I didnt have the best turning radius in the world, but it wasnt horrible. I could live with it.
Well after 7yrs the bds springs started sagging and I warrantied them out. When I found out the 6" ones were the same price, I opted for 6" springs and left out the zero rate so theoretically I would go up 1", well it went up 3"
. After I put it in I had no turning radius in either direction. So I had to drive the truck that afternoon, went and grabbed a dropped draglink because my stock one was at like a 45* down angle. That helped it out somewhat but my radius is still terrible.
When I turn, now I am almost an inch away from the stops on the axle, when before I was almost touching them. (cant adjust them cause they are stuck). If I had to guess, now when I turn to full lock the tire might be at a 40* angle from the side of the truck....Heck, driving down the road I have to input more wheel to make simple turns than before. Everything is tight in the suspension, just cant figure out wtf happened. I do have an agr box, but its been on for awhile, and I got it right before they went downhill in quality. Appears that the pitman arm is making its full range of motion and the truck still does its raising up and down when you turn like it did before.
Any ideas?
Box is tight to the frame, no cracks, have a brace, you can see the leaf springs flex a little when you turn the wheel, all the joints look tight (no massive movement), and I dont have $$ right now for x-over, any ideas?
. After I put it in I had no turning radius in either direction. So I had to drive the truck that afternoon, went and grabbed a dropped draglink because my stock one was at like a 45* down angle. That helped it out somewhat but my radius is still terrible.When I turn, now I am almost an inch away from the stops on the axle, when before I was almost touching them. (cant adjust them cause they are stuck). If I had to guess, now when I turn to full lock the tire might be at a 40* angle from the side of the truck....Heck, driving down the road I have to input more wheel to make simple turns than before. Everything is tight in the suspension, just cant figure out wtf happened. I do have an agr box, but its been on for awhile, and I got it right before they went downhill in quality. Appears that the pitman arm is making its full range of motion and the truck still does its raising up and down when you turn like it did before.
Any ideas?
