Ultimate 10 bolt axles
You can up the strength with CTM joints in the shafts.
I think at the price they ask for these and chromos, I’d probably start looking at a D60
Ive seen the Spicers spit out all the needle bearings and not break, also seen the shafts break and the joint live
Those CTM joints look BEEF. i may just get those.
as far as Dana 60s go, here in my area, they START at $2500. That would be for usually a pretty beat one. I would have to stick gears in it/locker plus all the other stuff would need to be cleaned /rebuilt. I would be looking at around $3500-4000 for a useable 60. I could spend $1500 on RCVs and stuff a locker in it for $500. And everything else in my 44 is ready to go. I get the investment is worth it, but there is other things on the truck that could use that $2000....
The choices are hard!
Yep, and a 60 is not a guarantee either. Guys break those on a TBI and 35s. I’d trust the Spicers, just rotate then out if you wheel hard all year. Don’t drive like a dill hole, it helps. Don’t back up with the wheels turned all the way
If you have a selectable front, unlock it before you back up
I will say that a spicer 760x joint in the Warn shafts I had in my K5 never broke. I did swap them each year
I haven’t talked to anyone running the RcV joints on a 44 though
I am getting them, I am just waiting for the money to come.
I have driven my k5 with stock axles and while I didn't break, I could feel the binding and the wobble when I was turned a little bit and then I had the chance to drive a backhoe 4x4 and they have cv axles and they are turned all the way, pedal to the metal, not a sound or movement, just smooth driving through everything.
So I am sold.
And as you noted @ $1500 they are reasonable enough compared to a d60.
Now the d60 rcp shafts are insanely expensive @ $2650
Why is that? Backing with the wheels turned all the way?
A friend of mine builds axles for a living. He has maintained for years that 2/3 axles break when backing
I believe some of it is stress unloading, like @ZooMad75 mentioned. Some may be over extension or pinch stress.
But 2 of 3 broken axles i asked about at Blazerbash happened while they were backing
8 lug 10 bolt front on 37's welded. I break a lot of hubs and I think I am on 3 shafts broken in 12 years. But I have zero horsepower well close.
I pop the front end out with the triple stick and doubler often and I normally only have the driver's side hub locked since it has the longer shaft. Sounds like wise advise to unlock either the front axle or hubs or both when backing. I have broken both stock shafts, warn, and yukon I believe was the last one. But then I am kinda chunky 6200 lbs.
I do have room in a garage if someone has a 60 with 4.10's that is in their way.
Are you installing that the same time as the new cross member?
also the u-joint is weakest working at angles . so wheels turned = faster to break a joint / pop a cap / eat a yoke end on the shaft .
Probably. Still need to get some 2nd gen parts to make the big block crossmember work for the small block. I need to call ORD and get the info on what I need. Also since I currently have 4 inches of snow and it's snowing hard it may be June.
I think you need the wedge piece of the motor mount off of a square body, but not positive
Watch from my video on flat iron I had one of my cameras mounted on top of the winch. You can see me barely drop the right front into a small hole. Forward motion stops and I begin to back up slightly. Then you hear it pop. The video should start at 35.01 just before that sequence starts.
Okay so I didn't put tires and power or driving style in on purpose so many of you guys would scream D60! just like several already have. I have D60, 14bolt, 9 inch and even 5 ton axles sitting here ready to be used. But I think that a lightweight axle that is built right will out live a stock D60 and give better overall performance.
So lets talk center sections is a high pinion 44 center that much than the 8.5 10 bolt? Or 9 inch? Or high 9?
Also let's not forget the rear axle 8.5 10 bolt, make it full float? 9 inch? New half ton axle with disk brakes? Wanting to stay light and higher center so half ton size.
