Did you just say air bags? That is designed into my new truck design. Needs to do 80mph with a boat behind it. Then wheel moab and tow home.
Yes I love air bag suspension! The ride is so nice and so easy to add load handling to! I think air bags and some of the air bump stops are going on everything I own.Did you just say air bags? That is designed into my new truck design. Needs to do 80mph with a boat behind it. Then wheel moab and tow home.
Very seriously thankful not sarcastic. I plan on keeping my 6.2L diesel and know weight is the enemy of mileage and performance both of which I want to keep so I am looking for that razor's edge to build to. I have other trucks that can be built to crush cars and climb mountains. But this truck I want to drive up to the valet and it get parked up front next to the Ferraris on Friday night and take my girls trail riding on Saturday then a 400 mile trip on Sunday with no breakage, good maintenance availability, and good mileage.Trying to figure out if you are being serious or not......and leaning towards you just being sarcastic?
What is a lighter double beadlock wheel? I plan on swapping the inner run flats out for the lighter plastic pipe ones, unless someone points me to a better setup. Also I have these already sitting here and they are a really bulletproof setup and street legal.I used a 9.5 SF14B in my 3rd generation Blazer. Super easy swap and not much penalty weight or size wise. If you’re trying to save weight humvee wheels and tires are a terrible choice. Ran those on my 80 K5 and “lightweight, maintenance free, long range (400 mi) cruising” don’t fit these requirements.
If need/want them there are aluminum double beadlocks out there that are not only lighter, but don’t have ridiculous amount of offset. Using them on 10B would be an outstanding way to negate the reasons you stated want to run the 10B. And (at least the last time I looked) you end up needing to use 16.5” tires. If you’re set on using them avoid the 8 bolt versions, but even the 12 bolt ones can be bent. They may be “bulletproof” (they aren’t) but they definitely are not rock proof. Also, don’t forget to replace the o-rings between the wheel halfs.What is a lighter double beadlock wheel? I plan on swapping the inner run flats out for the lighter plastic pipe ones, unless someone points me to a better setup. Also I have these already sitting here and they are a really bulletproof setup and street legal.
Single (1) Hutchinson 16x8 border patrol beadlock wheel
Have (1) single Hutchinson GM 'border patrol' forged aluminum dual beadlock 16x8 with '0' offset wheel for sale. complete with hardware. has defect of slightly under 2" overall length rock or curb rash on outer rim lip edge less than 1/4" deep at the deepest part. not very bad at all really...www.pirate4x4.com
Think it's funny that almost all of the street legal double beadlocks are made by Hutchinson the maker of the Humvee wheels. Anyone know the weights for the steel vs aluminum wheels?These are NOT the ones I was looking at buying 15-ish years ago, but these should give you some idea of options-
I’ll keep looking and see if I can find the ones I looked at. In the end I used 12B surplus humvee wheels on DRW D60 front and C&C D70 rear.
EDIT- Found them, they were Hutchinson’s. At the time they popped up occasionally on eBay coming off trucks from the ME. Probably too expensive to bother today. They are quality wheels though.
When I mounted them I had the weight of a bias 39” Swamper on a complete humvee wheel with rubber insert. Let me see if I can find it. But IIRC, the complete combo was just under 150 lbs each, 147 lbs per my bathroom scale comes to mind.Think it's funny that almost all of the street legal double beadlocks are made by Hutchinson the maker of the Humvee wheels. Anyone know the weights for the steel vs aluminum wheels?
Back in 2005 or so I mounted up a set of 36” Swamper TSL-SX’s on some recentered 8-bolt H1’s with a commercial grade cut to fit plastic pipe sections as the inserts in the Florida summertime heat and it just plain SUCKED !When I mounted them I had the weight of a bias 39” Swamper on a complete humvee wheel with rubber insert. Let me see if I can find it. But IIRC, the complete combo was just under 150 lbs each, 147 lbs per my bathroom scale comes to mind.
Any reason you want to run the double beadlock wheel in this application? Seems like a lot of weight and complexity for something you said wasn’t going to be your primary wheeler.
I just had a fun flashback of mounting them. That was a long day in the GA heat. I did six total, four 12 bolts on the truck, two 8 bolts as spares, and then the installation 4 rounds of 8 lug nuts. My torque wrench got a work out too, 96 nuts and studs. Lol.
Any outdoor activity in the Florida heat sucks.Back in 2005 or so I mounted up a set of 36” Swamper TSL-SX’s on some recentered 8-bolt H1’s with a commercial grade cut to fit plastic pipe sections as the inserts in the Florida summertime heat and it just plain SUCKED !
I would not wish that on anyone to do now that I’m older …
The answer is about 1/2" radius. Many are surprised to hear that the diameter of a 16.5 wheel is 16". Why are the tires marked "not for use on 16" wheels"? Because they fit...sort of.And also how much bigger brakes can I fit by going 17" vs 16.5? 20" I could see getting much bigger brakes on.
It’s that 45* rim lip angle on the 16.5’s.The answer is about 1/2 radius. Many are surprised to hear that the diameter of a 16.5 wheel is 16". Why are the tires marked "not for use on 16" wheels"? Because they fit...sort of.
