Ok I have a 77 k20, rebuilt 350 th400 np241c with slip yoke. I have a fresh built drives shaft w/new Spicer factory style 1410 u-joints and 1410 slip yoke custom built for this truck. Also just had my 14bff rebuilt with a 1410 yoke 4.56 gears and a detroit. I re-welded my spring perches and set it 2 degrees lower than the t-case output so if the pinion walks up it will be perfect with the t-case. -6 degrees on the tcase and +4 degrees on the pinion. Here's the catch it only vibrates after 65+ it's a pulsing vibration and it's SUPER annoying to say the least. It's perfectly quiet at 55. It has a shackle flip with 56" springs with I believe 1 or 2 leaves taken out, overloads are still in. Could that 2 degrees be causing the vibration? I'm at a loss here. It's always done it with other trans and other tcase's but everything Is new and we're it should be, I don't think tires could cause this type of violent pulsating vibration. Other than this the truck is a dream. I've been chasing this for years now and I don't know of anything else that could cause this! I'm going to get my tires balenced next week, they are Falken 315 70 17 on aluminum rims very low miles.
Thanks for any help,
-Daniel
-Daniel
