I've heard about Blazer bash a few times and now i've decided I want to go to Blazer Bash 2011. Never been to Moab, what are the most important things to have? What are good tires to run out there? I have a 77 blazer with a 6'' spring lift, 35'' tires, sway bar disconnect, 9500 pound winch on the front with a synthetic rope, tuned port injection in the works, 205 t case, front and rear diff guards, 1/2 ton axles with lock rights front and rear, power tank, high lift jack, and lots of recovery equipment, Ord engine crossmember, ORD front and rear shackles, and hoping to cage it before blazer bash. Thanks for your input.
