I reread that post linked, and I am guessing that your oil cooler is in the radiator, which would explain the oil temp being the same as coolant temp. The oil cooler is on the hot side of the radiator.
Mine is completely external, if any I worry about to cold. Now I am thinking I need an oil temp gauge. I have a trans gauge, which is in a horrible spot for me to read, and no room for another gauge. Current idea get a sender for the current gauge put in the oil system, and toggle switch the two senders to 1 gauge.
Would like to put the sender (Autometer 2258) in this plugged hole on the adapter. Am not sure this a good spot for a temp sender, right about oil pressure by pass.
Thoughts?
