Truck ran and drove 10 minutes b4, my wife had taken the truck to the vets and back no problem.
Well I spent the evening making my fuel issue worse. I found a spot were the pre pump fuel filter was rubbing,
I changed the filter and made a longer section of hose between filter and pump, to solve rub issue.
Start it up on choke runs good for 45 seconds, dies. Restarts and dies. Well s$_-.
Ok so I crawl under invade the 14 bff personal space, just like Joe would,
I see the whole line from sender to pre pump filter it looks fine. Get my trusty bendy flexy 1/4 drive carb adjusting tool with 1/4" deep socket, undo the clamp wiggle that hose off.
Looks good can't find an issue. New hose, with an extra foot or so, I get on clamp in position and tight. 14bff says I'm groping it, and owe it dinner by this time.
Give it a test siphon I immediately get gas only little thou. Hook the new hose from tank directly to pump, no filter. Try to start, wants to, but no go.
I can hear the pump running, but what hell I have another pump. Install new pump, no joy. Must be something wrong in tank. Just my frickin luck it's full.
Well I have an empty plastic 55 gal drum I'll siphon into.
Think I am going to buy a spectra tbi tank with in tank electric pump.
The sender and pick up are spectra, and @ 1 year old 2k-ish miles.
I don't know that the spectra part failed but am at a loss to come up with another explanation.
I stated earlier tank was coming out to do body mounts and shackle filp, just a bad time for it. Oh well stuff happens.
