the CK78x is 19x34". That's the one I put in my K5. it's a 3 row. It's in the truck I'm selling, you can see it in the pics on my media page.
Hey, I'm sorry, I thought I had posted up and answer for this. I meant to, but I guess age is starting to take a toll. This is the method I've always used: Test for electrolysis using a voltmeter (DC scale). Place the positive lead of the meter in the engine coolant without touching the radiator sides. Clamp the negative lead on the battery ground.
For the test to be valid, there needs to be an electrical load. To get that load, first disable the engine so it does not start by pulling the coil wire.
Crank the engine over while reading the voltage in the coolant.
Next, start the engine and retest loading individual electrical circuits by turning off the lights, heater, air conditioning, etc.
With a cast-iron engine, the reading should be no more than 0.3 (3∕10) volt. A reading of 0.5 volts will destroy a cast-iron engine over time, and 0.15 volts will damage any aluminum component or engine.
If voltage is discovered, shut off one electrical load at a time until the reading drops to zero. Then, identify and fix the ground path for that component.
There are other ways I have read and seen used, but that seems to be the simplest for me. There is really no reason there should be voltage across the radiator/coolant, even a little. If there is, there are other issues, so try to get that reading to 0, it will probably save you some other trouble in the end.
Enjoy your new radiator!
pretty convinced the coolant needs to be grounded or prevented from building up an electric charge in an aluminum radiator.
I need to test mine. That's not a lot of voltage for margin of error.
However, the coolant should be grounded, it touches the block. I find it hard to believe, but perhaps scale buildup in the block prevents it?
I believe I read somewhere that antifreeze is actually supposed to help with the stray voltage issue as well.
