What the Scout
1964-ish Scout 800/80 hot mess Scout. The only redeaming qualities of the truck are the rust free body and frame. Everything else look like a crack head had a good idea and went half way with it. Swapping a GM drivetrain.
Just as @imiceman44 said, its back burner, parts, plan, and PB is priority. I've been bugging them to work on it and get that answer.
Hey, yeah its a back burner item right now. I think last time i checked in we had the scout 2 axles and power steering stuff. After that i threw my back out and we got a ton of snow so its been sitting under a tarp. We are hoping to pickup a wrecked gm 4x4 this spring/summer to rob the drivetrain from.
Hopefully we will report back in the next few weeks after she has gutted it.
always had a soft spot for scouts. My first 4x4 was a stock 1962 scout 80. I flat towed it all over the place. lots of fun half cab/full cab/no cab... folding windshield... had thoughts of building one, but other things came up and a blazer found me.
biggest issue I saw with building one was how wide the frame rails are. they were perfectly straight and don't narrow in the front. unless going full width axles your turning radius will be crap. but, I had planned to pull the body on one, chop the solid frame cross members, narrow the frame rails, and then sleeve/ extend the body mounts back out to their original locations. really looked like something that could be completed in a weekend. its all flat metal and square tubing on those things. I was planning on using a set of landcruiser axles from an FJ62, setting the frame rails at the correct spacing for the factory spring perches on the front axle, and then relocating the perches on the rear axle as needed...
finished result would be a vehicle capable of u turns on most city streets? had to be better on the trail? something to consider I think!
that was the plan anyway... blazers and buggies for me now.
I can still hear those vacuum windshield wipers swooshing and making cool sounds as they failed to do much good for the visibility!
