In the truck now,,,TH 400 W/ 2200 rpm TCI stall convertor w/anti-balloning plate. Reverse pattern valve body. Competition shift kit. TCI deep cast pan.
Inline spin on filter w/autometer temp. gauge. Steel braided lines to bed mounted B&M plate tube cooler w/fan. B&M pro shifter
On the bench now,,TH475, modified pump,hardened input shaft,
low gear planetary,kevlar clutches,36 sprag clutch and drum,
plus all the above,,,
On the shop floor 465 w/ 205 case,
