What tranny are you running?
Turbo 400 with shift kit and np203 with part time kit, Would love to put the 465 and 205 back in, but the left knee can't take the strain anymore. /forums/images/graemlins/frown.gif
In the truck now,,,TH 400 W/ 2200 rpm TCI stall convertor w/anti-balloning plate. Reverse pattern valve body. Competition shift kit. TCI deep cast pan.
Inline spin on filter w/autometer temp. gauge. Steel braided lines to bed mounted B&M plate tube cooler w/fan. B&M pro shifter
On the bench now,,TH475, modified pump,hardened input shaft,
low gear planetary,kevlar clutches,36 sprag clutch and drum,
plus all the above,,,
On the shop floor 465 w/ 205 case,
my k5 has a turbo 400 with a shift kit, heavy duty sprag and clutches,deep pan and a 40k gvw cooler.
my tow rig has an allison /forums/images/graemlins/bow.gif i would love to have it in my k5 /forums/images/graemlins/peace.gif
I am not sure what mine is. It is a 4 speed manual w/low as the first gear. I am guessing it is the 465? Is this a desireable tranny?
was 700r4 with rebuild and shift kit and now my truck has got a 4l80e /forums/images/graemlins/k5.gif
Remington
TH350 went adios in favor of a SM465 a few years ago.
I do have a Dodge NV4500 variant sitting in my garage that needs a work over and hope to have it installed soon.
My K-5 has a 465 in it
My pull truck/ daily driver has a NV-5600 /forums/images/graemlins/thumb.gif
Tom
700r4 .Currently leaking....but soon to be re-built.And he better do a good job!!!!!!!!!!!! /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gifJake
Your poll is actually giving misleading results at a quick glance because you have split the 700R-4 options as well as the other 'auto' options. A quick look makes it seem like the majority of guys are running SM465's... /forums/images/graemlins/thinking.gif
TH400's (all) 19/116.....16.37%
TH350's (all) 26/116.....22.41%
700R-4's (all) 41/116....35.3%
All auto's 86/116....74.1%
SM 465's (all) 26/116....22.41%
NV4500's 0/116....0%
All manual's ....22.41%
other 4/116....3.4%
Rene
Yes... but it shows that 35% are running th700's compared to 22% that have 465's. Clearly, there are more th700's out there.
Currently..BPO T350 case with beefed up T350 guts and a 4x output shaft.
Going to get ready...BPO T400 case very beefed up /forums/images/graemlins/grin.gif
[ QUOTE ]
[/ QUOTE ]
Um...duhh /forums/images/graemlins/histerical.gif
That has nothing to do with choice, or even preference...GM installed the 700R-4 in 85% or more K5's from 83 on up.
Rene
[ QUOTE ]
Um...duhh
[/ QUOTE ]
K5 has a sm465
1972 C10 short wide has a sm465
1989 Cherokee has an AX-15, like it matters /forums/images/graemlins/whistling.gif
Chris
