actually mine had a manual choke with a pull cable
That im not too sure about. Suppose it depends on what year you order?
Also, Im certainly not advocating you towards electric choke tho they do seem to work best in my opinion. I have also owned a few rigs with the heat stove style like would be correct for your rig and liked them just fine. They are a good design and work. Over many years of heat the metal seems to not respnd to the heat as well and needs replaced but no big deal. If it were possible, (and it is) i would stick with HEI and heat stove choke.
Are you looking for a new carb?
wait a second......
What was the original question? I'm so confused. hahahaha
All you asked was "what's the triangle thing" and now we are talking about carbs. HAHA what did I miss.
To answer the question, it's a block off plate for your EGR. You don't need to run an EGR at all if smog doesn't require it. The TBI stuff needs it unless it's tuned for it missing. Carb setups don't give a sh1t about EGRs LOL.
most rebuildable used quads are in the $10 to 50 depending on what model, etc...
if your gonna have a carb, it should be the quadrabog...
kinda a "deathnail" for quads are bad shaft bushings.. if the throttle shaft has bore play.. kind of a nuisance to save at that point, but doable.. other than that, rebuilds are super simple...
