Whats your "wet dream drivetrain"....
Hmmm!... sorry if my choices made a few here upset-..
I dont dissagree with the fact most "car" trannies have less torque capacity and higher gearing in first than the SM465 does,and they might not be a good choice for a heavy truck--dont get me wrong,I think the SM465 is an awesome tranny (and the similar M20) for a large GVW truck like a C-60,that isn't expected ro be speed shifted and needs a creeper gear,I just didn't care for the wide jump between ratios in the ones I had,and the non synchro granny gear was not of much use to me in street driving...at least with a Muncie you can use all 4 gears and downshift it !..
My two trucks with SM465's had 3.08's,so that only aggravated their undesireable charecteristics...(I never felt the need for an overdrive ,thats for sure--felt like they needed another gear between second and third though)...
I have not even driven any 90's trucks with the newer manuals ,so I have no clue what they are like,but listening to some take off at traffic lights,they do seem too high geared in first gear,and like anything newer,they probably aren't built as rugged as the good old SM465 was...
I like the Alison automatics,one of those would be awesome behind a BBC ,like a 8.1 litre in an older truck..
Maybe I'm showing my age here ny praising the straight sixes,it may just be nostalgia why I am finding them more desireable as I grow older--their simplicity and ease of maintenence outweighs their "disadvantages" in my case--I would have no trouble plowing or going to the dump with my truck if I had a 292 in it,but I agree if Iwere to tow a trailer with it of any size it would be a very poor choice,and I'd want a 454 or a 8.1 in it!..but for what I do,the six would suffice,and hell,I've seen them in everything from 1 ton dumps to school busses,and they might not set any acceleration records at the drag strip,but they will run forever with any kind of maintenence..
The 283's and 207's & other small blocks were ALL WE HAD 30 years ago,and they seemed to be adequate then,when speed limits were 65 mph,so why are they any "worse" now..granted they might pale in comparison to a newer TBI small block,but look how much simpler they are to maintain and work on --there is no comparison...but then,I'm an old hippie stuck in the 50's and 60's who'd rather have points and carbs over computers and EFI...I like things I undestand,that are simple,and dont make me feel "stupid" when I open the hood!...
Some other drive trains I dreampt about were :
A 425 Buick Nailhead V8,with a "switch pitch" TH-400 and a divorced NP-205 T-case..now THAT would have plenty of torque for ANY use you could think of,and would be cool looking to boot...
The caddy 500 engines and a good Th-400 were a good swap for a GM truck,they look almost factory and are a simple swap...
I have seen an Alison V-12 aircraft engine grafted to a 70's GM truck,with an Alison tranny,but the guy who had it built was a milti-millionaire...very cool rig though!..it was only a 2wd,made exclusively for drag racing..but he took it to a few cruise nights too!...the engine went into the cab and had a "doghouse" like a van does,it was simply too long to fit it all under the hood...it looked like a 454 on steriods...
I saw a GMC V-12 at a swap meet back in may,that was built factory by joining two 351 GNC V-6's together.a "twin-six"--the thing was awesome,but you'd need a truck with a nose as long as a van to get the thing to fit under the hood!..you probably wouldn't even need a tranny behind that beast!..
a lot of guys dont like straight sixes,and I wasn't their biggest fan either actually,and have ripped 2 of them out of GM trucks in the past ten years to replace with V8's ,and was rather dissapointed with the results...I learned a lowly "camel humper" 250 has more guts than the '73 304 I put in my van,and the '86 305 I put in y '79 Bonnanza wasn't much better than the same six I yanked out of it...the v8's do get slightly better MPG's though,and seemed a teeny bit peppier...not worth all that work though!...:doah:..
BIG INCH 450+ Aluminum small block, 6 speed converted TH400 trans, Atlas T case, Greg's Unimog's :D.
You seen that article in Hot Rod too I take it :waytogo:
Yup. :haha:
I'd prolly detune it from 1200hp down to 500 or so and set it up more for torque than top end power - and it would need to run pump gas and be reliable. A 5.3 would be better for torque, but it would be too fun to tell a BBC driver that I just blasted past that I had a 4.8. :D
If your dreams upset people - you are probably on the right track! :waytogo:
Diesel4me, I don't understand the guys that like points either LOL, I mean whats simpler then an HEI? one 12-volt wire and your done. and they last . no setting points every 5000-6000 miles.
283's and 307's might have been all that was around 40 years ago but 30 years ago (1981) there were lots of 350's and 400's and 327's and 454's in 1981 . hell you could still get muscle cars cheap back then LOL
You really shouldn't get freaked out about the "new" Its just as easy to diagnose (maybe easier) its all still the came basic concept Suck-Squeeze-Bang-Blow. I'm sure with a little time you could learn it, especially if with sites like CK5 and Others like 3rdgen.org .
Obviously you were smart enough to learn how to fix the old stuff, with a little time you can be smart enough to fix the newer stuff.
12v Cummins (500 hp and 1000 ft/lbs), NV5600 6 speed, 203/205 doubler (lomax gears in the 205), dana 80s front and rear with 4.10s rcv shafts and ARBs, parallel 4 link front and triangulated 4 link rear with coilovers
I would be able to do 70 at 1750 rpm while still having a crawl ratio of 138.5:1 on 40" tires :pimp:
I saw a 63 or 64 GMC 1/2 ton truck modified to accept one of the GMC V12s at back the the 50's car show this year. was pretty neat. the frame and front fenders were stretched probably a foot to make that thing fit in there.
Ive also been thinking of getting a 66-68 Impala for a summer driver. A 283 with a 700R4 in a car should get pretty decent mileage, and with the overdrive I can to some extent, overcome the lack of displacement with gearing, all while having a nice driver that will keep up with traffic. Which at some point the 283 would be removed for probably a 5.3 and 4L60E. Thats just me day dreaming again though.
One of my best Chevies was a "old farts car",a 4 door '67 Impala,with a 283 and a Powerglide tranny--3.08 gears...dependable as they come...it got 18+ mpg and cruised nicely ay 70+ mph with no trouble,and though I dodn't really care for a 2 speed automatic,I was never able to kill that Powrglide so I could swap a TH350 in it!...a 700R4 would probably wake that 283 right up,with its lower first gear,and overdrive might make more MPG possible...
I had several other Chevies around that vintage--one was a '68 Caprice Estate Wago--had 58K on it when I bought it from a friends grandmother--the 307 in it needed a cam,had a few flat lobes on it--after I put a duntov 30/30 cam a friend had lying around from a vette motor he rebuilt,and a 4 bbl aluminum intake and a Carter AFB on it,the thing went amazingly well,and still gave 16-18 mpg on the highway..
I have nothing against HEI ignition,I have swapped many in place of points--I just like the fact points can ba a lot easier to troubleshoot if you lose spark--with NEI your just guessing its the module,till you replace it,hoping it will cure it...
Computers and sensors are what I dislike--that and the fact its a lot harder to get a vehicle inspected when the check engine light wont stay off,and no real "cause" can be found...and computers control way too many things--like the altenator voltage,etc..what was wrong with an integral regulator??...it used to be easy diagnosing charging systems,now you need to be a wizard...and have a "known good" computer to substitute to see if thats whats wrong-- half the time the scaners dont give enough info..
also,you guys all know about the "kill" chips in every GM computer,that can be activated by radio waves of a certain frequency??...points and carbs will fly right by when all the other vehicles die that have computers...:D
Computers can control an engine more efficiently and with more precision than any old mechanical method. Any Laptop with the proper software and OBDII scanner can diagnose any issue faster than the old trial and error method. It sounds as if your issue with mechanics substituting "known good" ECU's is used to the "old" ways vs the way things are done know. I see no reason why you would need a "good" computer to diagnose an issue when the OBDII software should pickup the bad ECU from the get go.
The new stuff is awesome...untill it stops working.
There is something to be said for opening the hood of say a 69 pickup...
For me the nicest thing about the newer rigs are the comfortable seats and better laid out interior controls. Little things like cruise control, strong wiper motors, a stereo you can reach without swerving, lumbar support.
Dream ride: smogged out 305, th700, 10 bolts with 3.08s...:D
Personally, I would dig a 292/SM465/205 in a 1st gen Blazer for a DD or mild trail rig. And since we're dreaming, some forced induction on that six for better acceleration.
Otherwise, I'd be pretty happy with a 383/TH400/203-205 doubler and some 3/4 ton axles.
GM zz383, built vortec heads, roots superchager like whipple or radix, efi. Built 4l80e. Klune v. 205/261 doubler. Gmc 2.5 tons just to be different, only care for front steering. All in a 99 ccsb, 41" iroks.
Can I play?
Older Cummins, no electronic B.S., NV4500, doubler, Locked tons, with hydro assist.
I cant do one because Ive got too many scenarios so Ill break down each.
KOH/Racer: Full Aluminum Roller EFI 572 Twin Turbo BBC, Aftermarket M22 Rockcrusher w/ straight cut 1st and 2nd gear, I dont even know what tcase could hold that... / Dana 60s front and rear stuffed with Jana dana 70 gear kits, solid knuckles and Cs with keyed steering and rcv shafts.
If I ever did a trazer again: tuned up 4bt/ NV5600/ 241-205/ same axles as above
Towrig: 90s 3500hd converted to 4wd w/ plainjane 1 tons and a CAT or Cummins from a tractor.
Expo rig: Mercedes OM617/ toy 5 speed trans/ toy doubler/ isuzu custom 12 bolt front with dana 60 outers, Arb
As stated, lots and lots of variables. but Ill limit to two.
DD -
First gen full convert,
4-53T detroit diesel with a jake brake, and compressed air starter (always thought that swap was awesome and has a nice touch of nostalgia)
NV4500
NP205 with lomax (3:1) gears
D60 kingpin DRW front axle unlocked 4.88 gears
D70 HD rear DRW with detroit locker and 4.88 gears
37in hummer take offs, mounted on unmodified H1 beadlocks.
Trail rig / B.O.B. (bug out blazer)
M1009
hybrid J code 6.2/1993 vintage 6.5TD engine (best bits of both)
NV4500
NP205 with lomax (3:1) gears, and NP203 doubler. tripple sticked.
D60 kingpin DRW front axle with ARB air locker and 4.88 gears
44in super swampers on unmodified H1 beadlocks with run flats.
Tow rig: Bagged 80's C30 with a CR Cummins, G56 or 5600 and the np241hd or whatever it is behind them factory. Setup works in my dodge, no need to change it.
Trail rig: My current limo with about a foot out of the wheelbase, a Turbo LQ4, built 4l80e, 241/205 doubler, assuming it could handle the stress, and steering unimog axles.
I'd also like to build a dune rig K5 with a china turbo 5.3, Th400, 205 and a semi float 14 and 10 bolt front with some good leafsprings and bypass shocks to run hard and put up wet.
I like to build vehicles in my head.. My daily driver wish list is about a mile long and contains lots of overpowered obscure stuff that wouldnt be practical to drive at all, let alone daily.
I'd love to have a Lomax 205 for my Doubler.
for a trail rig, the drivetrain I have in the Maiden is great, although I would like FI for the BB...maybe about double the size of fuel tank too!
For a tow rig...an old CC with a Duramax/Allison would be the balls!
