If I understand this, your engine is over heating, or not heating up ? you might also want to check if the fan clutch is Ok, they wear out after 25 years. You should have a 16 PSI cap on the radiator. And as said, you need to make sure the radiator is getting all the cool air as possible, IE: the fan shroud. needs to be in good shape and If my 88 is any example, you have a six bladed fan on your truck. Now this is just me, but when I restored my 1988 K5, I put a extra heavy duty transmission cooler in place of the smaller old unit, and I placed 1" sections of radiator hose inbetween the new cooling unit and the radiator, and the plastic ties go through the center of the hose pieces. This gives the radiator and the cooler some cool fresh air to be drawn in from the sides, See, you have the Radiator, the A/C Condenser and the Transmission cooler all stacked on top, or in front of each other. By the time any air gets back to the radiator it's pretty warm by then. So this gives the radiator some fresh air from the sides of the front. I'd pressure test the whole system. I hope I have helped.
