Want to connect my 8an fittings to regular fuel line. Do they make a fitting i can just put on or do i need to order all sorts of stupid crap to make it work?
I just went through all this trying to figure it out. I wasn't able to find any saginaw to AN fittings. My current plans are to just replace the whole line and use AN fittings the whole way.
Someone correct me on this but I think you could cut off the flare and use one of those tube & socket fittings which depending on the size of the tubing (likely 3/8") will get you -6 AN. I think the -8 only came for 1/2" tube.
