Which after market EFI?
Discussion in 'The Injection Section' started by brokenparts, Oct 18, 2016.
  1. mrk5
    mrk5 The Sticker Guy Moderator GMOTM Winner Author
    Apr 20, 2004
    15,314
    4,820
    Northern Colorado
    Build(s):
    Cool, I'm pretty excited this may be a good way to get a dual tank fuel system setup to feed FiTech or Holley Sniper.
    skunked likes this.
  2. brokenparts
    brokenparts 1/2 ton status Premium Member
    Mar 11, 2011
    718
    550
    hillsboro, or
    Build(s):
    How about the E-street? Any rumors with that set up?
  3. skunked
    skunked Orange Block Because Chevy Premium Member GMOTM Winner
    Feb 27, 2013
    12,556
    12,229
    Placer County CA
    Build(s):
    That matches up with my K5 lock ring and tank.
    mrk5 likes this.
  4. mrk5
    Apr 20, 2004
    15,314
    4,820
    Northern Colorado
    Build(s):
    Nice. I finally have a plan I'm happy with.
  5. Bent77
    Bent77 Black is the new Orange Premium Member GMOTM Winner
    Dec 3, 2002
    18,380
    19,890
    colorado
    Build(s):
    I'm gonna let you beta this one
    skunked likes this.
  6. skunked
    Feb 27, 2013
    12,556
    12,229
    Placer County CA
    Build(s):
    :waytogo:
  7. Kay86K5
    Kay86K5 1/2 ton status Premium Member GMOTM Winner
    Mar 9, 2012
    2,825
    2,053
    Emmett, ID
    Build(s):
    I just responded to my build thread on this scott, but others might care as well.
    I did just "resuse" a saddle tank sending unit, however I ended up after trial and error going with this sending unit:
    http://www.rockauto.com/en/moreinfo.php?pk=972608&cc=1061895&jsn=544
    It's still a replacement for my crew cab TBI 350 sending unit, however it had longer ports extending further off the sending unit than any other sending unit I found. And like scott has found, the saddle tank TBI sending units are a little different than the burban/K5 TBI sending units. Saddle tanks have a barbed end to just slip on a rubber hose and hose clamp like carb'd motors where burban/k5 tanks have the threaded fittings on the end. Those tanks are easier and you just get the adapters that @skunked posted earlier in this thread and run the new lines and your done (along with the EP381 pump). But mine I had to cut off the little barbed ends and slip on AN nuts/sleeves onto the line and then flared the lines. The reason why you really should get the sending unit I linked above is because with the other stock sending units, the only way to get the flaring tool on there is to bend the lines straight up, flare it, and then bend them back down. But when you do that it will cause hairline cracks at the bends on the tubes and it will leak (ask me how I know :D).
    Hope this helps people when looking at other options weather with saddle tank TBI tanks, or burban/K5 TBI tanks.
    brokenparts, skunked and mrk5 like this.
  8. brokenparts
    Mar 11, 2011
    718
    550
    hillsboro, or
    Build(s):
    @skunked where did you source that TBI tanks and sender?
  9. skunked
    Feb 27, 2013
    12,556
    12,229
    Placer County CA
    Build(s):
    Bought the Spectrum Tank & Sender along with the Delco 381 pump through RockAuto.
    brokenparts likes this.
  10. brokenparts
    Mar 11, 2011
    718
    550
    hillsboro, or
    Build(s):
    Gracias... I'm re-reading your build thread (for the last 2 days) and have not got that far yet. :)
    skunked likes this.
  11. mrk5
    Apr 20, 2004
    15,314
    4,820
    Northern Colorado
    Build(s):
    Maybe we should change this to the EFI sending unit thread. :rotfl:
  12. brokenparts
    Mar 11, 2011
    718
    550
    hillsboro, or
    Build(s):
    All good information going on here. I hope it continues.
    mrk5 likes this.
  13. mrk5
    Apr 20, 2004
    15,314
    4,820
    Northern Colorado
    Build(s):
    Yeah, I'm not complaining. Just find it interesting how a thread can end up going an unexpected direction.
  14. skunked
    Feb 27, 2013
    12,556
    12,229
    Placer County CA
    Build(s):
    EFI Tech V3.0 :D
    mrk5 likes this.
  15. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,932
    109
    Tucson, AZ
    I think there are benefits of sticking with factory style GM TBI in terms of being able to find parts and get help with fixes. You can upgrade the computer with DynamicEFI, which is what I did. They modify the factory computers so you can easily reprogram on the fly and do some rudimentary self learning. My truck has been running well since I upgraded. FiTech (and similar) does look slick though and I'd seriously consider it if I was starting over.
  16. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    706
    214
    Oklahoma
    Build(s):
    I had been set to do FItech next spring but I keep finding stuff in reference to bad customer service, and FiTechs seemingly having outgrown production capacity and tech support.
    As of right now I'm leaning towards the Holley sniper.
  17. ekajkrats
    ekajkrats 1/2 ton status Premium Member
    Mar 6, 2012
    1,099
    435
    North SF Bay Area, CA
    I've only emailed them once about my fuel pump meeting their requirements and the emailed me back the next day.
    That was this summer.
    It did take a while to get it because of demand but I ordered it knowing that.
  18. mrk5
    Apr 20, 2004
    15,314
    4,820
    Northern Colorado
    Build(s):
    I had a thought driving home today. Running E85 with the aftermarket EFI. I see FiTech supports it but the advertised horsepower it's capable of supporting drops quite a bit. I would assume the Holley system will to.
    Of course the rest of the fuel system needs to handle alcohol.
  19. gonefishin
    gonefishin 1/2 ton status Premium Member
    Apr 22, 2010
    924
    41
    spring tx
    i think i am going to order the 600 hp fitech kit. summit has it for 995 and then $100 rebate. I'm getting this next month. how many people are running this with a big cam? i have a 236/242 @.050 cam. it has a fairly lumpy idle. How well will this work?
    RubberFloorMat likes this.
  20. skunked
    Feb 27, 2013
    12,556
    12,229
    Placer County CA
    Build(s):
    You'll be fine.
    gonefishin likes this.
